Hey guys,
Anyone know what the spring rates are on the NA8 Clubman Bilsteins or a standard NA8 for that matter?
Paul.
Spring Rates?
- SKYHI
- Matty
- Noodle
Spring Rates?
Are the anti roll bar rates the same between the two cars ?
Spring Rates?
TCR wrote:Anyone know what the spring rates are on the NA8 Clubman Bilsteins or a standard NA8 for that matter?
Noodle wrote:Are the anti roll bar rates the same between the two cars ?
the anti-roll bar thicknesses are 19 & 11mm front & rear for a standard NA8, & 20 & 11mm front & rear for a Clubman. The US R Package, similar to the Aust Clubman, had 20 & 12mm front & rear - if you want to replicate this then just fit an NA6 rear anti-roll bar as they are 12mm PnP.
if you've not seen the Clubman FAQ you can find it here:
viewtopic.php?f=76&t=30041
