Vibrations!!!!!!!
spitty
Vibrations!!!!!!!
Postby spitty » Sun Apr 13, 2008 1:44 pm
I have a set of NB8A rims on my NA8. It would appear my son has flatspotted the 2 fronts ,not badly, but enough i thought to cause an issue. Jacked up the front and spun the wheels and one rim is about 1mm out of round :roll: :roll: . Is THAT going to be a problem aside from a flat spotted tyre, or should i try to locate a single rim[bigger problem] Cheers John
Postby sliq » Sun Apr 13, 2008 2:06 pm
i have a problem like that.. steering wheel gets vibrations when i go over 80-100km/h.... its because i've got a buckled rim..
best to see if you can get it fixed first.. if not, that single rim replaced.. in worse case scenario, buy a new set of rims :lol:
TieNN89
Postby TieNN89 » Sun Apr 13, 2008 7:03 pm
http://www.mx5plus.com.au/ might have some
I'm told these rims are easy to buckle
Postby Mr Morlock » Mon Apr 14, 2008 2:16 pm
Spitty that does not sound a real flash situation. However one of your friendly tyre / wheel shops should be able to check it and see if it is out of balance and whether it is rectifiable. I also imagine rims are buyable afterall cars do get recycled.
spitty
vibrations!!!!!!!!
Postby spitty » Tue Apr 15, 2008 9:49 pm
Thanks chaps
Rim is certainly out of round . Will drop off tomorrow to have it rerolled [$120] Wish i,d read the MX5Plus add 1st :roll: :roll:
thanks John
SuperMazdaKart
Postby SuperMazdaKart » Tue Apr 15, 2008 10:38 pm
going to Adelaide Wheel & Rim Works? they guy behind the front desk is a turd. much friendlier service at the Wheel repair place directly across the road haha (can't remember there name but it's where I went to for re-rolling my old daisy NA6 wheel). get a quote from both.
spitty
Vibrations
Postby spitty » Wed Apr 16, 2008 7:37 pm
G,day Vu. Thanks for that . I,ve had work done on these rims before at \"Extensive Wheel Services\". Very good job but expensive. @ $110 per rim. I hope this is the end of these issues otherwise there will bee a set of NB8A rims for sale. Pick it up Friday ,,,, hopefully the tyre is not flat spotted [badly]. My son wont be driving it again unless i,m in with him :lol: :lol:
Cheers John
Users browsing this forum: No registered users and 337 guests
