i have a big list of jobs i need to finish before natmeet and this is one of them.
got some adj. bars and appropriate bushes. are there any tricks or anything i should look out for to make the job quicker / easier? any tips?
is getting the bushes on easy enough? or do i need a special tool.
thanks for any tips.
fitting new swaybars
- Steampunk
anti-sway bar bushes have a cut along the length of them so you just slip them on, so to speak. No tools required whatsoever.
Were you thinking that you need to thread the whole bar through the hole?
If the bush does not have a cut longitudinally, it simply means they are brand-new and never been installed, thus you have to make the cut yourself.
Rear swaybars is super easy to do. Front sways require a bit of moving about to get around it. Either jack up the car both sides or better still, do them on a ramp. Tip for the front sway: remove the undertray.
The poly D bushes just slip on easily. Put lots of grease on them or else they squeak. End link bushes on the other hand...
Fatty wrote:manga_blue wrote:Get it up high on good stands to do the front one. Back one is dead easy.
You can bring it round to my place if you like.
you busy tomorrow phil?
No, just tinkering before Winton. Just call and check first that I'm home.
NP James.
BTW I threw your old thermostat into a saucepan of boiling water. It didn't budge. I reckon that, stuck where it was, it was blocking about 80% of your coolant flow. The effects of that would be that the car would have just enough flow to not boil with normal street driving, but after 2 or 3 laps of a track ... up she goes.
Does that sound painfully familiar?
manga_blue wrote: The effects of that would be that the car would have just enough flow to not boil with normal street driving, but after 2 or 3 laps of a track ... up she goes.
hmmm now that does sound awfully familiar, yes
here's hoping that particular problem is well and truly solved .
Users browsing this forum: No registered users and 30 guests
