Restoring my Simmons V4's *now installed*
green_comet
Car Detailing Guru
Postby green_comet » Wed Mar 19, 2008 12:10 am
Hey guys,
Just though I would do write up on the Simmons wheels I have been working on for the past couple weeks. They are Simmons V4's in 15x7 +35 offset, I bought them off of a friend who ran them on his MX5 for a while.
The wheels were quite battered when I got them, The centres were chipped, scuffed, and the powdercoat was peeling off in places. The lips were very gutter bashed, damaged by prior wheel weights, and were in a good need of repairing and polishing. The tyres were in good condition though, and have about 80% left on them.
When I got them.. you cant quite make out the poor condition in the pic. :?
It was time for me to fix them up, I started by removing the tyres, and pulling the wheels apart in 3 pieces. The powdercoat had to be removed, so I was off to see a local sandblaster. I was informed that powdercoat was very hard to remove with a sandblaster, and that it would take hours to do the wheel faces. I rang around to about 5 different sandblasters and was told the same thing by all of them. :?
So I decided to try some paint stripper, I used quite alot and let it soak in for about 30min, success!! The powder coat was starting to lift and peel off. Removing the powder coat was very time consuming, as it sticks alot better than paint. It took about 2 hours of work on each face to be totally powder coat free. After that I removed the baked on brake dust, on the rear half of the wheels, using a wire brush drill bit. I also filed out all of the gutter rash and polished the lips up a little, using mothers mag polish.
Wheels pulled apart, and powder coat stripped to reveal alloy cast centre.
After The powder coat was stripped I was ready to move onto the next stage, working out what colour I should make the centres. I was thinking black powder coat, but I decided against it as I would have lost all of the detail in the centre. I finally decided on gold powder coat, which I think looks nice on a white car.
I rang around to about 9 different powder coaters to ask about gold colours, with no luck. I was told that there are only 2 options in gold powder coat, so I went down to have a look and both were not to my liking. The gold's were too dark, and would have looked silly on a white car.
In the end I recommended by one powder coater to get them painted the colour gold I wanted. He gave me the number for Advanced Alloys in Moorabbin, so I gave them a ring to get a quote for getting the centres painted, and a few casting holes repaired. I was quoted $350 to get them done, which I wasnt prepared to pay, as thats more than what I paid for the wheels, with tyres. :shock:
I decided to give it a try myself, I have done a few panel repairs before, and know how to paint...why not?
I went and had a look around and found some Gold enamel paint in a spray can. I bought a can and went home to see how it would come out on one of the faces..
With no prep I sprayed one of the centres and mounted it back onto the wheel. I was very pleased with the colour, so I went back and bought some more paint.
Gold enamel, no prep and no clear..
Once I had purchased all the paint I needed, I went to work on the centres, stripping the one I just sprayed, filling all the casting holes, and little imperfections. After a couple days work off and on, they were starting to look pretty good. I then sanded the centres down, and made sure the bits I filled were nice and smooth, and cleaned them up with prepsol.
green_comet
Car Detailing Guru
Postby green_comet » Wed Mar 19, 2008 12:12 am
It was time to paint. I used about 3 cans of gold enamel all up on the 4 centres, I put it on quite thick and let it dry outside in the 40 degree heat. :shock:
Three have been painted. The silver one still needed to be sanded, cleaned, and painted.
After I finished painting all the centres it was time to clear coat them. I bought some Urethane clear coat wheel paint, which is meant to have a very durable finish. It should be good to protect the paint from break dust, stone ships, sand, salt etc. So after the wheels had dried I hit them with the clear.
Centres all painted and clear coated.
With the paint sorted and still drying, it was time to visit the local metal polishers. I couldn't quite get the results I wanted doing the polishing at home, so I went to Complete Metal Finishing in North Sunshine, and dropped the lips off to get polished. Lance is a great guy to deal with, and did an excellent job. He got out all of the stone chips, and also polished out the damage the wheel weights had done to the lips.
The lips came back like mirrors! Here they are waiting to be re-assembled. 8)
Lastly was assembling the wheels, fitting the bolts, torquing them all up and applying silicone sealant to make the two halves air tight.
Installing bolts and using some thread locker.
The fist wheel is assembled, sealed and ready to go.
All four done and finished, I'll let the silicone dry overnight and get the tyres fitted tomorrow.
Im very happy with the way they came out, I will get some pics up tomorrow when they are on the 5.
Cheers guys
Ryan
Craig
Postby Craig » Wed Mar 19, 2008 12:28 am
Great write up and great result, looking forward to the pics of them fitted! 8)
Adam_NAclubman
Postby Adam_NAclubman » Wed Mar 19, 2008 12:40 am
I'm not a fan of Simmons wheels, but they look bloody fantastic! I ought to pull my Volks apart and do them
Lucky_Luke
Postby Lucky_Luke » Wed Mar 19, 2008 9:25 am
Nice work!
I cant wait to see mine after a respray when i get em back!
Not a huge fan of the gold, i liked em better silver but they do look pretty damn bling!! I've always been a fan of the polished lip!
Show us some pics of them on the rig!
DIY all the way! :D
L.
AB7
Postby AB7 » Wed Mar 19, 2008 10:22 am
Great stuff!!! nice size and offset too
Ajay
Postby Ajay » Wed Mar 19, 2008 10:41 am
i had a set similar to those i sold for a stupid cheap price not knowing what they were worth!.. beautiful 16\" alloy's
stupid kid :(
they look great though
wun911
Postby wun911 » Wed Mar 19, 2008 11:39 am
Not my type of wheel but looks nice...
every ounce counts
Steampunk
Postby Steampunk » Wed Mar 19, 2008 11:47 am
take a bow! good job mate!
Benny
Postby Benny » Wed Mar 19, 2008 1:49 pm
Great job there green_comet.
What's your address so I can send a couple of sets of wheels to you? :mrgreen:
Postby Hammer » Wed Mar 19, 2008 4:34 pm
Worthwhile read. Thanks for sharing.
So what do they look like on the car?
Cal
Postby Cal » Wed Mar 19, 2008 4:39 pm
Wow they look awesome. I have a set of V4's under the house that need doing up. They have been powder coated white all over, including the lip. I reckon gold like that would look great on BRG.
sprx3
Postby sprx3 » Wed Mar 19, 2008 5:35 pm
the only thing that would have made them look better is to apply hi fill to the centres but i dont blame you for not doing that, i would hate to sand it ALL down again..... great job, they look as good as new ....
cant wait to see you crusing the west side with them on ;)
want to join the mazda car club of australia?, for more info please p.m me
green_comet
Car Detailing Guru
Postby green_comet » Wed Mar 19, 2008 5:38 pm
sprx3 wrote:the only thing that would have made them look better is to apply hi fill to the centres but i dont blame you for not doing that, i would hate to sand it ALL down again.....
I was planning on doing exactly that, but after spending soo long on the centres with removing the powdercoat, and sanding it all down. I would have gone crazy sanding all the hi fill, so I just sanded,primed, and painted, as I really wanted them on the car asap.
Hammer wrote:Worthwhile read. Thanks for sharing.
Very cool... 8)
Just got them on about an 30min ago, then went to take some pics.. :D My new front spoiler looks invisible in the photos.. :?
Im very happy with them, they suit the car nicely. :D
Ryan
fattima
Postby fattima » Wed Mar 19, 2008 5:40 pm
Very nice work they have come up a treat. Look good on the car as well, a real credit to you.
Users browsing this forum: No registered users and 109 guests
