I want to move the pedal closer, and I tried doing it the \"normal\" way from the interior by:
- undo brake-light switch and wind it out
- remove pin securing pushrod bracket onto brake pedal
but the problem is the bracket where the brake-light switch sits will only allow the brake pedal to move 3mm closer to the driver.
You will understand what I mean if you pop your head under the dash.
So does anyone know of a trick to move the brake pedal closer?
brake pedal height adjustment
- Steampunk
- Steampunk
Sasso wrote:Why don't you lower the accelerator pedal instead?
Thought about that too.
I'll pop me head under the dash again.
There is a large adjustable bolt that acts as a stopper, if I wind this down:
- accel pedal sits farther away
- accel cable gets tauter
- adjusting accel cable slack is easy
only problem will be the amount of pedal movement and throttle butterfly opening at full open throttle.
I'll have a fiddle and see how it goes. Thanks.
And Tez, I have a headache so no glib comebacks for you tonight except a stern, "No"
Users browsing this forum: No registered users and 115 guests
