quick question - does anyone know if these will fit on an mx5??
are stud pattern, offset compatible? these are off the 4wd version
nissan pulsar rims on mx5???
- Jimmy
The hub diameter on the pulsar wheels is also slightly too large at 59mm. You would need to machine some hub adapter rings with outer diameter 59mm and inside diameter 54mm no company makes them in this size. I just did this for a mate on the metal lathe out of aluminum (although his pulsar wheels stud pattern was 4x100)
- MxJadeMonkey
