Seized caliper
Andrew
Seized caliper
Postby Andrew » Sun Feb 17, 2008 11:02 am
Anybody got any tips on unsticking a rear brake caliper :?:
JBT
Postby JBT » Sun Feb 17, 2008 11:23 am
Unwind the adjuster :?:
Andrew
Postby Andrew » Sun Feb 17, 2008 11:28 am
JBT wrote:Unwind the adjuster :?:
Not too sure that will help.
Caliper is now off the car and the top slider pin wont come out of the hole and when i turn it the thread just loosens by about 270degrees and thats it.
Think I may have to take it to ABS in the morning and get them to recondition it :(
JBT
Postby JBT » Sun Feb 17, 2008 11:57 am
OK, didn't realise you already had it out. I thought you meant the piston was jammed. Got a photo to explain the issue?
Andrew
Postby Andrew » Sun Feb 17, 2008 12:56 pm
JBT wrote:Got a photo to explain the issue?
Kind of what No.9 is pointing to in your image.
The slider pin is stuck -
Outside brake pad -
Inside brake pad -
CT
Postby CT » Sun Feb 17, 2008 6:54 pm
Hey Andrew, I spent 20 minutes rebuilding two rear calipers today! The only way I have removed one is WD-40, some heat and some \"attitude adjusting\" with a small brass faced hammer. About two months ago, I had the same issue on the front left of the NB8B - luckily I had a couple of spare sliders as one was pitted and no good. A good reminder for all to regrease the sliders at least when you change pads. moreso important if you do track days.
wun911
Postby wun911 » Sun Feb 17, 2008 7:05 pm
What kinda grease do you use?
Where is the slider pin?
Sorry for nube quesions
every ounce counts
JBT
Postby JBT » Sun Feb 17, 2008 8:26 pm
Don't the two parts (mounting bracket and caliper) twist apart?
CT
Postby CT » Sun Feb 17, 2008 8:55 pm
On the rear, there is a 10mm combo bolt/slider and a slider on the other end. Must undo the 10mm one to seperate the caliper from the mounting bracket. Use high temp brake grease - I use one from Repco that is PBR branded. Most hi temp moly lubes are OK - thin smear is all you need on each slider.
JBT
Postby JBT » Sun Feb 17, 2008 9:37 pm
Well I'm confused....so the lower bolt could not be undone? I thought the photo was of the upper bracket/caliper area.
I use Sta-Lube Brake Caliper Synthetic Grease.
Postby Okibi » Sun Feb 17, 2008 10:29 pm
Yup, I use the PRB stuff and relube them at least with every pad change.
Juffa
Postby Juffa » Mon Feb 18, 2008 9:42 pm
Casey had the same issue recently. I believe he had a brake shop sort it out for him. Same happened to me on a NA6, I ended up getting a 2nd had caliper from a wreckers. It is fairly common on our rear brakes. Pays to re-lube the slider pin on a regular basis. I have been using high temp grease, but have also seen specific brake grease in some auto shops.
J
Fatty
Postby Fatty » Tue Feb 19, 2008 3:00 pm
same thing hapened to me as well, brakes starting grinding at calder the other week. the outside pad looks fine but the inside pad is knackered.
i am replacing with na8 rears this friday.
Marty
Postby Marty » Tue Feb 19, 2008 7:42 pm
It took about an hour to get mine out when it seized but the way I sorted it out was to slide an open end spanner into the gap so the open end was over the slider pin and then try to lever it out a bit. Then when the gap was big enough I put another one in next to it and kept levering it with wedges between the spanners.
Dodgey as hell but actually worked.
Silver SP 153.7kw atw for $2
Andrew
Postby Andrew » Tue Feb 19, 2008 8:06 pm
Got the caliper back from ABS today, $38.50 total cost (including parts) which thought wasnt too bad.
Freed and replaced the slider pin, replaced rubbers where required and lubed ready for installation.
No hopefully i can install it before it gets too dark :?
Users browsing this forum: No registered users and 104 guests
