Hydraulic Handbrake Setup?
CapitalF
Postby CapitalF » Mon Feb 04, 2008 6:51 pm
Has anyone installed a hydraulic handbrake on their NA? Im doing more Motorkhanas and with the grippy Toyo R888's on it the std system isn't coping.
It appears there is a single hydraulic line going to the rear so shouldn't be too hard to plumb into that - correct?
Other tips / hints?
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
Postby bruce » Tue Feb 05, 2008 1:53 pm
It sounds like something you would need to be engineered to be legal.
I wonder if any of the drifters have installed one?
Postby Okibi » Tue Feb 05, 2008 3:30 pm
One of the SR20DET MX-5s has a hydraulic handbrake.
I'll see if I have photos at home.
CapitalF
Postby CapitalF » Tue Feb 05, 2008 10:19 pm
Cool - thx Okibi.
Im thinking I'll use the std handle mechanism and be able to dis/connect either std handbrake or hydraulic so at events it will be hydraulic (with ratchet disabled) and other times std cable...
Still researching...
Peter
Brendan_aussie
Postby Brendan_aussie » Tue Feb 05, 2008 11:40 pm
my MX5SR20 det has a hydraulic handbrake. it was easy to fit. Much easier than the last one I did where I had to try and battle with ABS.
the only downside is that when you push the brakes in it pushes the handbrake off (unless you attach a separate caliper to the disc and run a separate hydraulic line) so the trick is drive... brake... turn... release brake... apply hydraulic handbrake and around you go
i did mine all up for $600
Postby Okibi » Wed Feb 06, 2008 12:02 am
Is you car Warwick Gates' old MX?
Brendan_aussie
Postby Brendan_aussie » Wed Feb 06, 2008 12:08 am
thats me. I fitted the handbrake in attempt to keep up with these bloody Evo's and Sti's. works a treat on the turns, but the launch is still a problem with only 2wd.
the std handbrake is rubbish and cannot be adjusted to be effective if you have sticky tyres
Postby Okibi » Wed Feb 06, 2008 12:21 am
Warwick had the same issues.
There's a few more pics on this page:
http://www.mx5club.com.au/news.php?eitem=2007072900
Alex
Postby Alex » Wed Feb 06, 2008 8:20 am
depending on how much force you need I remember there was a modification that could be done to the standard brake to increase the handbrake force, someone else can find the thread I'm sure
Because I'm too lazy to google
zoomzoom
Postby zoomzoom » Wed Feb 06, 2008 10:13 pm
The first step is to adjust the little allen grub screw in the back of the caliper that is hidden behind a bolt.Adjust this up and it makes a great difference to teh things grabbing.
If you are looking for a hydraulic setup then I believe most of the rally guys just use a brake master cylinder from a series 2 or 3 landrover(cant remember exactly which one) it has a remote resivoir. The rear brake line is run up into the car and through the cylinder which is connected to either the origional handbrake lever or another one. But ofcourse this system would more than likely be illegal on the road. I have seen people fit a second set of rear calipers just for the handbrake though not on an mx5.
CapitalF
Postby CapitalF » Thu Feb 07, 2008 8:28 am
Brendan_aussie wrote:...
OK - great - can you describe how you did it? Im assuming you've looped the rear brake line up to where the hand brake is and plumbed it in with the h'brake. Is there a design to avoid the foot brake issue without having a sep system /calipers?
Thx
Peter
CapitalF
Postby CapitalF » Thu Feb 07, 2008 8:30 am
Okibi wrote:Warwick had the same issues.
with beating the Evo / STI's or the handbrake operation? :D :D :D
Peter
Postby Okibi » Thu Feb 07, 2008 5:42 pm
Both :mrgreen: :lol:
Brendan_aussie
Postby Brendan_aussie » Thu Feb 07, 2008 10:06 pm
zoom zoom is exactly right. the landrover kit system was the first one I went for, but then I split the slave cylinder, so I went for the Stewart Wilkins motorsport kit (www.swmotorsport.com.au) and that worked really well.
I mounted a vertical brake lever in front of the existing handbrake (and kept the existing handbrake) Its a neat fit with little flex and pleanty of leverage. Happy to post pics if anyone interested
regards
brendan
CapitalF
Postby CapitalF » Thu Feb 07, 2008 10:31 pm
Brendan Aussie - yes - Pics pls!
Peter
Users browsing this forum: No registered users and 186 guests
