teins which way to lower
- 16bit
just wondering which way I screw the teins to lower them - seems stupid i know
- Matty
- CapitalF
- Vehicle: NA6 - Turbo
Note that if you lowered the car a lot you may well need a wheel alignment to prevent significant tyre wear and ensure handling is not negatively effected.
I dropped my NA 30mm in the rear and slightly different (much smaller) amounts in the front to level the front up (L/R) and needed a wheel alignment big time.
Peter
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
- 16bit
