strut brace fitment. Will the nut fit back on the bolt....?
Posted: Thu Nov 08, 2007 9:02 am
by Steampunk
Hi all.
Very simple quetion; I bought a strut brace and am anxious to know if there is enough thread on the stock upper strut bolts for the nut to be secured back in place after fitment of the brace?
The end plates/brackets of the brace is approx 4mm thick.
Any suggestions appreciated.
Andrew
Posted: Thu Nov 08, 2007 9:09 am
by Garry
On my NA8 there were heaps of threads left. On my friends NA6 there were stuff all.
Posted: Thu Nov 08, 2007 9:15 am
by Juffa
As per Garry's reply....my NA6 has stuff all thread left. Having said that my cusco bar has been fitted to two of my MX-5s (both NA) and I have never had a problem with it.
J
Posted: Thu Nov 08, 2007 9:38 am
by Okibi
Same with the whiteline sway on the standard NB hats/studs.
You should be fine if your shocks are still stock.
How much thread is above the nuts currently?
Posted: Thu Nov 08, 2007 9:41 am
by Steampunk
Thanks fellas, that's a load off my mind.
It's also a Cusco brace Juffa (I think it's the OS series) so I'm counting on your experience.
Oki: just using my eyes, a guesstimate is about 6mm of actual thread
Posted: Thu Nov 08, 2007 11:41 am
by Slugoid
With stock mounts on my NA6, very little as well. The bolt was sticking a few mm (~5mm) past the nut iirc. But it should be ok as my car already came with a struct bar and i've been driving it for almost 2 years with no problems.
You can get some aftermarket uppermounts if you're paranoid but I don't really see the need.
Posted: Sat Nov 17, 2007 7:56 am
by Veloce
I bought one off eBay and had to reduce the thickness of the nuts by 50% and hacked off some of the thread as it bottomed out in the bar. Not happy Jan!
Posted: Sun Nov 18, 2007 8:40 am
by Steampunk
That's a bummer Veloce, were your upper strut bolts standard? (If they were then they have a conical/pointy top)
How thick were the end plates of the bar you bought?
