getting a sway bar today - setting?
Posted: Wed Nov 07, 2007 10:13 am
by 16bit
Hey guys I am getting a whiteline adjustable front swaybar today. I have tein ss on 6/6 with 6/5kg springs. What setting should i put it on to start with - soft?
Posted: Wed Nov 07, 2007 10:20 am
by franjae
I've just installed mine over the weekend. You go from soft and dial up from there if required. Even at softest setting your new sways will be +% stiffer compared to the std bar.
Posted: Wed Nov 07, 2007 11:26 pm
by Slugoid
On my NA6 I have it on medium as I can't put it on the softest or else it will rub against the shocks.
I also have Tein SS and using stock rear bar and atm I find it quite nice. It's a very neutral setup, with a hint of oversteer. Yet to give it a try on the track.
Edit: I realise you have a NB8, so I guess softest setting would be a good start as NB8's tend to be less taily compared to NA6's.
Posted: Thu Nov 08, 2007 9:24 am
by 16bit
this is one of the new ones with only two settings - oh well. i drove it a little last night and it was great. yet to push it past 5/10.
Posted: Thu Nov 08, 2007 11:43 am
by Slugoid
16bit wrote:this is one of the new ones with only two settings - oh well. i drove it a little last night and it was great. yet to push it past 5/10.
5/10? Is that the setting your Tein's are set to front/rear away from hardest?
