whiteline adjustables sways adjustments
Posted: Sat Nov 03, 2007 4:39 pm
by irwin83r
hey all.
just went to adjust my front bar and make it a little stiffer and realised its already on the hard of the TWO settings.. is the front bar only meant to have 2? the rear has 3...? i seem to remember someone on here saying they had their front on the medium setting.. wouldnt that mean theres 3?
what are other people running?
Posted: Sat Nov 03, 2007 7:48 pm
by RobbieRat
Thats interesting, mine has 3 holes front and rear, mines set as follows front max rear medium.
Posted: Sat Nov 03, 2007 7:52 pm
by Craig
Posted: Sat Nov 03, 2007 10:13 pm
by butters
mine has 3 holes front rear aswell.
i use front med, rear soft.
i tried hard front and back but on rough roads it was skipping a bit instead of letting the shocks work properly (teins) if you do track work i'd try hard
it's up to you but having the rear a little softer will make it less twitchy
They may of done without the soft on the front due to possible rubbing on shocks??? or inabillity to get the end links to reach?? for memory the racing beat ones only have 2
Posted: Sat Nov 03, 2007 11:18 pm
by irwin83r
thought something didnt look right... \"sigh\"
what you guys think drill the third hole myself or hit up mania for a replacement?
Posted: Sun Nov 04, 2007 9:35 am
by RobbieRat
i'd be measuring the hole centers and comparing them to a 3 hole bar, your bar may not have the softest setting, which in my opinion is useless anyway as most run medium to hard.
Where does yours have room for another hole?
Posted: Sun Nov 04, 2007 4:45 pm
by Slugoid
RobbieRat wrote:i'd be measuring the hole centers and comparing them to a 3 hole bar, your bar may not have the softest setting, which in my opinion is useless anyway as most run medium to hard.
I don't think it's even possible to run on the softest (outermost) setting with the Whiteline bar without aftermarket end links. I've got mine set on medium with factory end links and there's less than 1cm or clearance between the end link and the shock body. With the softest setting the end links will be rubbing the shocks.
Posted: Sun Nov 04, 2007 8:34 pm
by tbro
Posted: Mon Nov 05, 2007 12:38 am
by zoomzoom
The na and nb has the same rear but a different front, so it may well be that the nb one is only supposed to have 2 holes.
Posted: Mon Nov 05, 2007 12:28 pm
by irwin83r
if it were meant to have three the two holes i do have would be soft and medium.
it looks like theres meant to be another hole.. but if someone with an NB whiteline front bar could confirm that would be sweet... if not i guess ill have to look at other ways of firming up the front
Posted: Mon Nov 05, 2007 2:47 pm
by CT
My old NB whiteline wasn't even adjustable - be happy you have 2!
Posted: Wed Nov 07, 2007 12:39 pm
by Charlie Brown
Probably meant to have two.
This won't help you but the front adjustable bar for the NC only has two holes. The outside hole (softest) matches the lever lenght of the standard bar but is 67% stiffer.
Posted: Tue Nov 20, 2007 10:59 pm
by irwin83r
got in touch with mania who got in touch with white line and yeah only meant to be two holes..
however the car did feel better with the new alignment but id dunno.. still think theres more to be gotten out of the cars handling.. maybe i should upgrade from streets to something more motorsport developed..?
