Page 1 of 3
Wheel and Suspension Facts And Figures
Posted: Wed Oct 10, 2007 3:39 pm
by Okibi
I thought i'd start a sticky with Chris's advice regarding suspension modification.
Perhaps we can add some OEM wheel specs etc. and make this a great starting point to answer the regular questions.
mx5racing wrote:Suspension heights are are calculated via a vertical measurement from the wheel centre to wheel arch.
These measurements are specified by the vehicle manufacturer at the time Aust Compliance is granted. A new vehicle data sheet (NVD1) is issued to the various State/Territory rego authorities. The NA6 NVD1 is known as MAZDA 26 and states the following -
A NA standard is 350 mm front and 370 mm rear. Minimum allowed is 320 mm front and 335 mm rear.
The 100 mm rule is minimum ground clearance for any item (except wheel/tyre).
A lot of aftermarket suspension kits drop the cars lower than minimum spec. .......
Road Vehicle Descriptor (RVD1) sheets replaced NVD1 sheets in 1999. They gave additional information including measurements at full bump and minimum ground clearance (101mm). The last one issued for the NB8B series was RVD1MC-152 issued 20/11/2003.
NB8B FRONT 352 SE 345
REAR 371 SE 364
MINIMUM
FRONT 351 SE 344
REAR 370 SE 363
MINIMUM AT FULL BUMP
FRONT 265 SE SAME
REAR 271 SE SAME
Basically
any lowering of a NB8B is outside the RVD1 specs and can be defected. The only way around this is to have an engineer inspect the car and issue a certificate. Just another way for the bureaucrats to **** us off……
NB8A FRONT 352
REAR 371
MINIMUM
FRONT 322
REAR 338
Posted: Wed Oct 10, 2007 3:47 pm
by Okibi
Posted: Wed Oct 10, 2007 3:56 pm
by JBT
Posted: Wed Oct 10, 2007 7:24 pm
by Okibi
Posted: Wed Sep 17, 2008 3:04 pm
by sliq
viewtopic.php?f=76&t=15398here are some alignment specs posted up by Charlie Brown
Posted: Tue Apr 14, 2009 12:39 pm
by MINX
NB8B
FRONT 352 SE 345
REAR 371 SE 364
Just measured my SE heights. Iassume it is Std SE suspension, done 45k.
Front 320
Rear 345
Seems even all round.
Posted: Tue Apr 14, 2009 12:51 pm
by philz
needs more low, you should be under 300mm on all corners
Posted: Fri May 08, 2009 12:19 pm
by ebola
I'm in the process of officially getting an engineers cert for my Rims (16x7) and a few other bits and pieces. My Engineer showed me this doc, which unfortunately applies to us all in NSW possibly other states too:
http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi09_rev4.pdfKey points are:
1) For Vehicle weight between 801 - 1200kg the rim width increase above the widest optional wheel available for the axle assembly used is 39mm (1.5 inches)
2) A 25mm increase in wheel track limit also applies
This means on My NA6 cooming with 5.5 inch standard my max width is 7 inches.
I wanted 9inch 6ULs
Posted: Fri May 08, 2009 12:31 pm
by philz
engineers certificate for wheels??
Just go 15x9
Posted: Fri May 08, 2009 2:25 pm
by ebola
philz wrote:engineers certificate for wheels??
Yeah well I have just passed my BD roll bar, Autotechnica seat and a few defects. Part of the engineering checklist is the wheel track, wheel sizes and checking tire ratings etc. So by default it gets done.
Aparently one of the most common fails is having lower load/speed rated tires than standard. If you ever see a Hummer with 22inch 35profile tires, chances are they are under speed/load ratings. My NA has a tire rating of 82. The Falken Azenis RT215s I am running have a rating of 87, so its all good!
On the other side, I couldn't get my Harness passed because it does not carry the ADR approval tag on it.
If anyone knows of an ADR approved harness please let me know.
OK, enough of the beige pants.
Posted: Sat May 09, 2009 12:41 am
by Sean
I'm interested to hear the wording (and actual situation) with the rollbar.
The rules around proximity to vehicle occupants and padding are pretty strict and I would have thought they ruled out classification and certification as a roll bar. My understandinging (could be wrong) is that it could only be passed as a style accessory, as a style accessory it's likely it could be self certified.
I guess it all comes down to the individual engineer
Posted: Sat May 09, 2009 8:47 am
by Matty
They can call it a fish tank as far as I'm concerned, as long as they sign the piece of paper.
Posted: Sat May 09, 2009 9:40 am
by ebola
Sean wrote:I'm interested to hear the wording (and actual situation) with the rollbar.
I was nervous while he was inspecting and measuring everything. He had a massive protractor and list of things to check. It was actually an asset to have the Autotechnica seat in the car because is doesn't recline. Another snagging point is that the roll bar is mounted to a seatbelt mount. Which the standard advises against but the engineer deemed to be acceptable. The third was that I was asked by the engineer to cover the roll bar in foam. It actually looks pretty tough like that however I cannot close the roof.
I'm finding a solution for that today.
Posted: Sat May 09, 2009 5:40 pm
by Sean
Cool,
The padding must satisfy his wants, like I said, engineer to engineer it can vary a fair bit. At the end of the day most of them are covering thier own butt as much as caring for the actual rules.
Posted: Sat May 16, 2009 12:27 pm
by Adam_NAclubman
I'm planning on getting the foam for my bar and strapping it down at certain points with cable ties because I want to slice a bit off the top so the hardtop fits over it
