another tyre choice
- 16bit
another tyre choice
After a bit of a run on friday the old pirelli's started to let go so i will need to get new tyres. I was thinking the Bridgestone Adrenaline RE001's but after hearing about the Goodyear Eagle F1 GS-D3 i might go them. Price is comparable @ $141 each for the 195-50-15 bridgestones and $149 for the goodyears in the same size.
What do you guys think.
http://www.goodyear.com.au/TyreDetailAc ... m=nPerPage
- 16bit
yeah i read it after i posted - as usual
I have sent them an email asking if its possible to pick the country of origin but dont like my chances.
that said i am thinking of going a bit extreme and getting these!
http://www.dunloptyres.com.au/TyreDetai ... m=nPerPage
in 205-50-15 in the hard compound. they are street legal and considering i have dríven my car about 5k in a year i should get at least a year out of them! They are quite expensive at $340 a tyre but that is fitted, ballanced, scrubbed in on the track with a data sheet of pressures and temperatures etc and a sprint session if there is one on the day.
- Brad
- 16bit
neither me - but that said they are a newer tyre. Also the evo magazine test has rated them as quite a bit better then the competition. I got a reply from goodyear though.
I think I may end up spoiling myself and getting the dunlop's.
Hello James,
You will be able to tell the country of origin from a marking on the sidewall.
It must be said, that all Goodyear tyres are \"fit for purpose\" and regardless of
origin, will fulfil their design characteristics and performance parameters.
We are not aware of any 'batches' that warrant concern.
Generally, it is the size that dictates country of origin. Some are made here,
some Luxembourg, some China, some elsewhere.
Hope this helps some way.
Regards,
Goodyear Customer Service.
\"James Rogers\" <james@depasquale.com.au>
01/10/2007 11:41 AM
To <goodyearmarketing@goodyear.com>
cc
Subject F1 GS-D3
I am considering getting a set of these http://www.goodyear.com.au/TyreDetailAc ... m=nPerPage. I have heard some bad reports about the quality of certain batches. Is it possible to specify its country of origin or tell on the side wall of the tyre where it is from. Some people have said the Thai made ones are \"undrivable in all conditions\" but the German made ones are \"the best I have ever had\". The car magazine reviews are all well and good but i would dare say you make sure they get the german ones - i don't want to be in the unhappy lot of people if i decide to get this tyre. Any help would be much appreciated.
james rogers
print co-ordinator
de pasquale
07 3852 4588
Fax 07 3852 4577
Level 1/358 Wickham St Fortitude Valley
PO Box 880 Fortitude Valley Q 4006
www.depasquale.com.au
Hello James,
Regards,
01/10/2007 11:41 AM
cc
Subject F1 GS-D3
james rogers
print co-ordinator
de pasquale
07 3852 4588
Fax 07 3852 4577
- CT
- 16bit
- Brad
$271 sounds very expensive for the RT615's. I would of thought they would be low $200's. I had them in 14\" and they were very good as an all purpose tyre. Took heat cycling well, quite grippy on the track when hot, though nothing like a 888. That said, the 888's won't heat cycle well at all and will go off fairly quickly.
After driving my car (195/60/14) and Cal's BRG (205/50/15) back to back with the same tyres, all I can say is there was a WORLD of difference, all put down to chassie setup and strength (he has under car bracing).
- fattima
I just got the Falkens but got 14 inch. Pretty happy with them have given them a good try out found them to have good grip for my power and are fairly predictable in the dry and wet. Do have a hunt around on prices, I got qouted from $245 down to $187 so some places are putting on some big mark ups.
- 16bit
- fattima
I'm in Melbourne got them from here
http://www.magwheel.com.au/
- 16bit
hmm after reading the thread above its pretty hard to go past the bridgestones for the money. Especially with a the comment about them being better then the more expensive rt615's i am looking at. i think i may have to go with my head on this one. with the left over money a bit of sway bar action may be had!
- Brad
I was going to make a late change from the S-Drives to the Bridgestones but was too late. I'm happy so far though, and at $150ea they were not hugely expensive.
*shameless plug mode* I'm selling a set of 14\" NA8 wheels with RT615's if you want to give them a go *end shameless plug mode*
