Kings $$$
AB7
Kings $$$
Postby AB7 » Mon Aug 06, 2007 12:42 pm
Hi Guys,
Kings fitted on NB for $380.00..is that reasonable?
I also searched on the forum, and most ppl said Kings on standard shocks is not a good idea.
I had Koni adjustable before on my FD3S, and the height can also be adjusted. Is that the same case with NB's Koni?
Thanks.
StanTheMan
Postby StanTheMan » Mon Aug 06, 2007 12:56 pm
$380 is quite reasonable I think.
As far as NB shocks go.......they will prolly last another 10-15k km after you install the Konis. But that also depends how far they have traveled before you install the The Konis. Mine lasted about 1 month. They had traveled less than 100k Km at the time in an NA
NB Konis are not height adjustable as far a I recall.
AB7
Postby AB7 » Mon Aug 06, 2007 1:45 pm
Thanks Stan.
I think I'll save up more money and do the shocks as well.
CT
Postby CT » Wed Aug 08, 2007 9:03 am
I had kings with stock shocks and they were fine with over 80000klms on them. It was a bit crashy when the shocks bottomed out but most of the time, it was a good thing. In fact, I only upgraded to Teins to get the car a bit higher so it could get over speed bumps.:)
AB7
Postby AB7 » Wed Aug 08, 2007 1:26 pm
CT wrote:I had kings with stock shocks and they were fine with over 80000klms on them. It was a bit crashy when the shocks bottomed out but most of the time, it was a good thing. In fact, I only upgraded to Teins to get the car a bit higher so it could get over speed bumps.:)
Hei CT, how low does it go?
Did you do this to NB?
