FITTING WHITELINE STRUT BRACE
Posted: Fri Jul 20, 2007 4:39 pm
by Ajay
hey guys..
just wondering is it very hard to fit a whiteline front strut brace.. im going to pick mine up after work tonight..
do i need to drill anything?..
your help is appreciated
Kind Regards
Ajay
Posted: Fri Jul 20, 2007 4:44 pm
by Mr_Q
It's dead easy - just don't over tighten the nuts at the top of the shocks 'cos they snap off fairly easily (don't ask how I know :P ).
Posted: Fri Jul 20, 2007 5:11 pm
by Ajay
Thanks Mr.Q
may sound like a stupid question but if i undo the 2 bolts above the shock will the shock shoot through?.. so there is no danger in me undoing those bolts?.. just thought id ask..
so basically i un-do the 2 bolts on either side..
put it under the bolts and tighten them (not too much :D)
Ajay
Posted: Fri Jul 20, 2007 6:51 pm
by dv8one
That is all you need to do.
It is quite safe!
Goodluck
by sabretooth
No danger at all. I've even drĂ­ven around without those 4 nuts on - though I wouldn't recommend it.
Posted: Fri Jul 20, 2007 6:59 pm
by Boags
Mr_Q wrote:It's dead easy - just don't over tighten the nuts at the top of the shocks 'cos they snap off fairly easily (don't ask how I know :P ).
Ya. :oops: Very easy to do. Mazda quoted me $180 (no, I haven't accidently added a digit) to replace the top. $10 from MX5Plus. 8)
Posted: Fri Jul 20, 2007 7:16 pm
by Andrew
My install - link.
Posted: Fri Jul 20, 2007 11:23 pm
by Ajay
thanks andrew!
ended up going to mania after work.. luckily dave and daniel were working on the race car so david put it on for me :)
i havn't detailed the engine recently so it looks a bit grotty!..
thanks for the replies guys :D
Ajay
Posted: Sun Jul 22, 2007 1:02 am
by Boags
When are you going to get a polished radiator cover?? 8)
Posted: Mon Jul 23, 2007 9:00 pm
by irwin83r
Boags'MX5 wrote:When are you going to get a polished radiator cover?? 8)
and throttle body :)
Posted: Mon Jul 23, 2007 9:13 pm
by marcusus
Boags'MX5 wrote:When are you going to polish my radiator cover?? 8)
Fixed :P
