tein Super Streets
Posted: Thu Jul 19, 2007 7:04 pm
any regular track boys use tein ss?? how do they cope with regular track work and daily driving??
Australia's biggest and best MX-5 forum!!
https://mx5.net.au/forum/
Please read the rules re: advertising on the Forum. I would also suggest that you modify your Sig file as well to remove the advertising from there.RaceSupplies wrote:Brother Trav
Super Streets handle daily driving perfectly. It's what they're designed for. If you intend on tracking the car, i'd recommend Flex ($2099 through me). If you want to track the car regularly, then Mono Flex would be a good move ($2395).
Both Flex and Mono Flex allow height adjustment from the base of the shock, so as not to alter pre-load on the spring.
I need to show you some to give you full appreciationI have some Mono Flex for Hellmun coming in on monday. If i have them long enough, you're welcome to take a look. Or maybe come from a drive down when i drop them off to him?
pcmx5 wrote:RaceSupplies wrote:Brother Trav
Or $1387 from PerfectRun unless I have done the maths wrong!!!!
Or $1671 for Mono Flex.
I bought in a little item through them and they were superb; strike while the dollar is strong!!!
Peter
