Posted: Thu Jul 12, 2007 7:17 pm
A quick look at the tech archive would have got you the following:
http://www.aus-cartalk.com/viewtopic.php?t=15398
Australia's biggest and best MX-5 forum!!
https://mx5.net.au/forum/
Miata Bart wrote:I told him I was basically an every day driver that wanted an allignment that would not cause excessive wear but would work well then I thrash it through the roundabouts. He knew what I meant, cause thats what I got.
marcusus wrote:Miata Bart wrote:I told him I was basically an every day driver that wanted an allignment that would not cause excessive wear but would work well then I thrash it through the roundabouts. He knew what I meant, cause thats what I got.
Do you know what settings he used to set your car up like this? I assume thrashing it through the roundabouts is not too dissimilar to hooning around the track
