Hi Everyone,
I have an urgent request for assistance regarding specs for a wheel alignment NA Miata running 195/60/14.
I have had nothing but problems trying to get a steering rack re-built, installed correctly, wheel aligned etc......
Suffice it to say I now have the rack installed ( almost ) and tomorrow it's booked in for a wheel alignment.
So, if someone could help me out by providing me with the Specs for a front and rear wheel alignment including the castor and camber tonight it would be very much appreciated.....
I have asked Mazda Mania to help me with this information but like usual I receive little or no response. Sorry to say but their customer service is disgraceful.
Eagerly anticipating a response......
Many thanks in advance
Patrick
URGENT - Wheel Alignment Request
- bigdog
- King of the kennel
A quick look at the tech archive would have got you the following:
http://www.aus-cartalk.com/viewtopic.php?t=15398
- Miata Bart
Hi Paddy,
I have received nothing but brilliant service from Mania over the past 3 years. Funny you should mention allignments as I had my NA done only this week (Wednesday) after spending a couple of hous with Dave & Simone.
When I asked Dave about wheel allignments (years ago) his respone was something like \"you can set them up any way you want\" & while that might not seem helpful at first, it is exactly right. Anyhow he pointed me to Beaurepairs at Hornsby & Ive used them ever since.
So, after having him fit me some braces to the underneath of the car I went around & had the wheels done, again.
The drive home to the Hunter Valley was flaming brilliant so say the least!!!
The trick with wheel allignments is finding someone who actually knows what they are doing & really, its not so much the \"correct settings\" but what you are going to be doing with the car. The \"standard settings\" should be available from anywhere with a machine but the question really is \"what do you want\"?
The bloke doing the allignment wanted to know if I was doing any track work, what the perceived problems were, what I was looking for, what style of driving etc.
I told him I was basically an every day driver that wanted an allignment that would not cause excessive wear but would work well then I thrash it through the roundabouts. He knew what I meant, cause thats what I got.
I drive over an hour to get to a place that knows what they are doing, I dont mind that because it is more than worth it. I wouldnt let the local blokes here touch my car with a stick!
Anyhow, my suggestion is find some blokes down your way that are really happy with where they go & have a yack with the bloke who is going to be on the spanners. Most of them wont mind you bringing it back to try something a little different if you arent completely happy.
Good luck.
Good luck.
- marcusus
Miata Bart wrote:I told him I was basically an every day driver that wanted an allignment that would not cause excessive wear but would work well then I thrash it through the roundabouts. He knew what I meant, cause thats what I got.
Do you know what settings he used to set your car up like this? I assume thrashing it through the roundabouts is not too dissimilar to hooning around the track
- Miata Bart
marcusus wrote:Miata Bart wrote:I told him I was basically an every day driver that wanted an allignment that would not cause excessive wear but would work well then I thrash it through the roundabouts. He knew what I meant, cause thats what I got.
You know, I didnt even ask because I liked what I got from last time I said rhat ;) . I could always give him a call & find out though. The other amazing thing was the price...... $60. Bargain!
Users browsing this forum: No registered users and 148 guests
