Yeah have tried both of them and ended up with the kings
while being slightly firmer i found the car responded well with them
also the whiteline springs came down about 5mm more than the king to around 35mm, a little too low i think.
plus kings have lifetime warranty (agaist free height sag of more than 10mm)
hope that helps!
compare king Vs whiteline
- MxJadeMonkey
Kings aren't very good. I have a set in my 93 all they are is hard they have very bad response this makes dampening them difficult I wouldn't even consider buying a set of them without Koni shocks. In retrospect I would save a little longer and buy a set of coilovers. Do the job properly, you will see a set of Koni/Kings turn up on this site every other month with always the same reason coilover upgrade.
- MxJadeMonkey
- Ajay
- MxJadeMonkey
- deez
