Worn Koni ?
Mr Starlet
Worn Koni ?
Postby Mr Starlet » Thu May 31, 2007 10:35 pm
Hi everyone
Finally had a chance to take out the springs to check shock condition. The two rears are pretty consistent, but front left is significantly softer in jounce than front right, bounce feels the same though. Is jounce a significant issue? how much should it cost to rebuild?, should I be rebuilding both to maintain consistency?.
Minh
UPDATE:
Did abit more research and realised I've used the wrong term.
By jounce, I mean compression; and bounce, I mean rebound.
Is there a trick to adjusting compression so that I could match the two front struts?...fully compressed then turn knob? something like that?. It's bizare how the rebound is still consistence but the compression is soft on one side.
Would it make much difference if I was use the way it is?...you would think a lot of the compression forces are taken up but the springs, I suppose the compression damping helps control spring compression rate.
Sorry, total brain dump mess at the moment :( :roll:
Mr Starlet
Postby Mr Starlet » Fri Jun 01, 2007 12:11 pm
* TSR (Total Shockabsorber Reconditioner), Slack Creek - Been here before they don't seem very professional, $98 base service.
* GSA (Wholesale Suspensions) - Across the road from TSR, sounds pretty good on the phone; only recons Koni and guarantee genuine replacement parts, $130 base service.
* W.W Shock Absorber, Virginia - $120 total service regardless of worn parts...:?
Anyone had their Konis recon in the past? workshop recommendations in Brisbane?
JBT
Postby JBT » Fri Jun 01, 2007 12:20 pm
Try Fulcrum. Avoid WW.
Mr Starlet
Postby Mr Starlet » Fri Jun 01, 2007 12:28 pm
JBT wrote:Try Fulcrum. Avoid WW.
Thanks JBT, called Fulcrum this morning and going by what they were saying; they charge significantly more just for checkup...by the time they finish rebuilding I'd be up for the cost a new one.
Known problem with WW? they include strut Dyno afterwards as well.
Mr Starlet
Postby Mr Starlet » Fri Jun 01, 2007 1:28 pm
Slugoid wrote:...The Koni Aus website says Fulcrum and GSA are the main distributors in Brisbane, so if Fulcrum is too expensive go with GSA. $130 sounds about right if it's for one pair.
$150 for the pair is cheap, the $130 quote I mentioned was for the ONE strut...and that's just for base service (new oil, new rubber seals etc, not including valving work if required)
Abyss
Postby Abyss » Fri Jun 01, 2007 2:03 pm
The first set of Konis I ever bought were from accurate suspension at Woodridge. They revalved them when I bought them to match the springs and never had an issue with them.
This was quite a few years ago and they are till in the same spot.
I would give them a ring and see what they can do:
Accurate Suspension
2/9 Timms Court
Woodridge
3808 2878
10AE #5522, Blue, the only colour to have. Every K over is a thriller
JBT
Postby JBT » Fri Jun 01, 2007 3:04 pm
Mr Starlet wrote:....called Fulcrum this morning and going by what they were saying; they charge significantly more just for checkup...by the time they finish rebuilding I'd be up for the cost a new one.
MX-5 Club Discount?
Mr Starlet wrote:Known problem with WW? they include strut Dyno afterwards as well.
Thery're good for repairs to lever arm shocks (MGB) but I'd go elsewhere for the Konis.
Mr Starlet
Postby Mr Starlet » Fri Jun 01, 2007 3:48 pm
Ended up dropping them off TSR, cheaper they are but they do have a long list of happy customers, myself include (from the Starlet days); better the devil you know I guess. Fingers cross everything goes well, if so I might get them back at the end of the day in time for the installation this weekends.
Minh
Mr Starlet
Postby Mr Starlet » Wed Jun 06, 2007 12:21 am
Ok finally!, after what started out as being a simple strut change, eventuate to that plus Kings springs, machined rotors, new pads, brake and clutch flush...I'm bugged!, and I was even thinking about bigger brakes.
Anyway it's all done now; went for a test drive with Konis on the softest all the way around...quite impressed with the ride quality, not sure if the shocks contribute to anything at all but it felt like there's a little more body roll than the harder settings. Went for another spin on 1 turn firm and boi the difference was quite noticable...wonder what's full 2.25 turn (firmest) would be like...
Quite impressed with the recon work, Simon at TSR really knows his stuff.
Will I need an alignment?...I know I should but theoretically if for some miracle I was able to maintain the same ride height on all four corner as previously than I guess geometry should still be the same?...in that case an alignment is uneccessary?...how much of a change in ride height will seriously affect geometry/handling?
Should I give it some time/km for the suspension to set before taking to aligner?
Sorry for the pile of Qs....still a newbee I guess :P
Minh
Users browsing this forum: Google [Bot] and 5 guests
