What size R888 for 15x7 rims?
Li7hium
Postby Li7hium » Tue May 01, 2007 3:48 pm
Well the old Toyos are starting to look more slick than semi slick now and I am looking at getting a set of R888s for club days and the Supersprints.
What size tyre should I get looking for? 195/55/15?
Any advice on this issue appreciated.
Thanks!
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
Craig
Postby Craig » Tue May 01, 2007 4:34 pm
205/50/15's of course! :P
Charlie Brown
Postby Charlie Brown » Tue May 01, 2007 4:36 pm
You can go to 205x50x15 with the 7\" rim or down to the 195x50x15s.
I think I'd stay away from the 55s due to more sidewall movement on the rim, bigger diameter and more weight.
Also the diameter of the 205x50s is less than the 195x55 tyre, faster acceleration out of those tight corners, though I shouldn't tell you that.
Bevan
Postby Bevan » Tue May 01, 2007 4:40 pm
Li7hium
Postby Li7hium » Tue May 01, 2007 4:43 pm
Thanks Craig and CB!
It turns out that the original size that I posted is out of stock Australia wide until some time in December.
Having a few places search for 205/15/15s for me.
Bev: With the amount of rims that I have already purchased from Craig, do you really think I need ANOTHER set?
:P
Matt
NA8
BRZ
Craig
Postby Craig » Tue May 01, 2007 4:45 pm
:lol:
Li7hium
Postby Li7hium » Tue May 01, 2007 5:01 pm
$250 a corner sound about right for 205/50/15s???
NA8
BRZ
Boags
Postby Boags » Tue May 01, 2007 8:10 pm
Sounds pretty good actually. I dread to think where I'm going to find the cash to replace mine when they die... :cry:
irwin83r
Postby irwin83r » Thu May 03, 2007 9:08 pm
wheres that from matt if you dont mind me askin?
Li7hium
Postby Li7hium » Thu May 03, 2007 9:38 pm
Hey Andrew,
From O'Neills Tyres in Wallsend.
You going to respond to your PM? :P
Matt
NA8
BRZ
