NC Wheel Alignment - Perth
Charlie Brown
Postby Charlie Brown » Wed Mar 21, 2007 8:25 am
Can't help with a good aligner but have a look here for your alignment specifications.
http://www.aus-cartalk.com/viewtopic.php?t=16263
As for your tyre pressures, 29psi as on your door plate is fine. Don’t get sucked into putting 36psi+ into the tyres cause you will bounce from bump to bump and loose cornering grip.
Join the WA MX-5 Club, they will \"steer\" you in the right direction. :D
tinsfci
Vehicle: NA - V8
Postby tinsfci » Wed Mar 21, 2007 7:49 pm
Wheels World in Osborne Park do a good job with 10% discount for MX-5 club members. They will align to your specs, so have a look at what other NC's are using and take the settings with you. Not as cheap as a generic job, but you will get exactly what you want.
Street='94 with FFS Coldside. Sold :(
Race='97 with AVO (soon to be Absurdflow) and GT2560 <--- sod that... LS1 conversion underway!
Charlie Brown
Postby Charlie Brown » Thu Mar 22, 2007 12:48 pm
To answer your question, yes, your rear wheels should look like / \\ from behind. That's negative camber that we talk about.
The amount of negative camber for a standard NC on the rear is about 1 degree and on the front a quarter of a degree however you can increase this another ½ degree to further improve your handling without any noticeable increase in tyre wear. I’m currently running -2 degrees and have run up to - 2 ½ degrees on the rear but then that’s aimed at track days and not normal road use.
Some of the racing boys in the US of A are now running half a degree more negative camber on the front compared to the rear. This is to improve the understeer in low speed corners that the NC has. I have test yet to test this but may give it a go before our next track day as I want to back my camber off a bit.
Postby Okibi » Thu Mar 22, 2007 10:39 pm
Yup, John and Bob at Wheelsworld in Ozzie park has done MANY club MX-5s including my own.
You can ask for a discount because you're in the MX-5 Club, I don't think there's an official percentage, probably more on a case by case basis.
DOYLMX5
Postby DOYLMX5 » Thu Mar 22, 2007 11:23 pm
I have been pointed to another mx5 guru at bridgestone in welshpool.
I was told he races lots of rx-7's or that he used to and that he knows a lot about how mx-5s should be.
That was just a refferal a good friend gave me but it might be worth a look.
The bridgestone there is on the corner of Sevenoaks and John street in Welshpool. Can't remember the guys name but Okibi might know something more...
mx52nv
Purple Porsche Eater
Postby mx52nv » Fri Mar 23, 2007 12:09 pm
Hi Brian,
Can't go wrong with Kerry Wade owner of B'Stone Bentley.
He has been racing since he was a kid and sets up all the LF Performance race cars. Won WA Street Car state championship 5 years in a row in the blue LF Performance FD RX7 and even set up Kim Ledger's own EVO 6 tarmac race car (seen usually at the AHG driving centre).
He also set up my car, which is now finally spot on - in fact don't take my word for it and ask ex-Dutton rally campaigner Warwick Gates who has test dríven my car and can't believe how it changes directions now.
Kerry will also be setting up Andrew's NB8 turbo next week with complete coilovers & SuperPro bushes together with the alignment.
He is just an \"old skool\" laid back guy that has so much knowledge its not funny.
See him racing the Sports Salon car next weekend when the V8 SuperCars come to town.
mr_rotary
Postby mr_rotary » Wed May 02, 2007 3:08 pm
I have my allignments etc at Warren's Tyre & Brake Service in Morley. I have had his work done on a few of my vehicles and also the RX-7 track car. Always happy with his results.
277 Walter Rd Morley 6062
9375 9994
