Hi guys,
does anyone have a link to instructions for rebuilding the calipers?
any tips?
Caliper rebuild
- godfather of saké
Pretty self explanatory, I think.
Press on the brake pedal a few times to use up the vacuum assistance, then I unbolt the calipers, and I suspend the caliper in a bucket (I raise the bucket on a few bricks so that the caliper can rest on it inside).
Then gently press the brake pedal a few times and at some point the caliper piston will pop out. Then undo the brake hose, inspect for cracks and take the caliper to your bench.
Clean it with brake cleaner, and make sure that the inside of the caliper where the piston lives is clean and free of any rust. Remove the o-ring from the old piston and slide on the new o-ring. Lube up the inside of the caliper with a little fresh fluid and slide in the piston. Fit all the new rubber seals, etc that come with the caliper kit, but remember to use lots of hi temp anti seize compound on the slider pins.
Refit the caliper to the hose, put back on car, refit pads and bleed the fluid. Repeat on other side
It's pretty easy to do, the tricky part is to get the piston out without squirting fluid everywhere.
- Garry
Thanks Babalouie. Just one more question. The hi-temp anti seize compound, could I use trailer axle grease or should I use something like graphite grease.
The kit I ordered through ABS. Mazda were more expensive.
'95 front you need a kit for each caliper.
'90 Front was just one kit for both calipers.
'90 & '95 rear you need a kit for each caliper.
I'll post serial numbers later when I have the invoice in front of me.
- godfather of saké
phatMX wrote:Thanks Babalouie. Just one more question. The hi-temp anti seize compound, could I use trailer axle grease or should I use something like graphite grease.
...I think you should use a product made by Loctite, called...."Hi Temp Anti Seize Compound"
- john!
- godfather of saké
Depends on whether you get a new piston and slider pins with it. If not, then it's just a bag of new rubber bellows and an o-ring for the old piston. IIRC I think it's pretty cheap, like $30 or something.
But some places that reco them professionally will hone out the piston bore, etc so there is lots you can do.
Users browsing this forum: No registered users and 155 guests
