16\" Continental tyres - I'm hooked for life!
SuperMazdaKart
Postby SuperMazdaKart » Mon Feb 19, 2007 5:17 pm
Continental ey, these the same brand that makes your favourite Creamy Mushroom Chicken dinner? :lol:
Craig
Postby Craig » Mon Feb 19, 2007 5:37 pm
Blackmax had these on his 5 and he loved them from all accounts.
RDM
Re: 16\" Continental tyres - I'm hooked for life!
Postby RDM » Mon Feb 19, 2007 10:51 pm
[quote="Chris P"]
3) In the wet - we are going through a heatwave, no water around anywhere, but I can't wait for winter.
[/quote]
Hehe... I've been using these since the OEM 17" Toyos wore out in 15k km... First got a set of 17" ContiSC2 (they were $350ish per corner). Loved them to bits... then when that set wore out 30k later, I put on a set of OEM 16" NB rims on along with 16" ContiSC2 and still loving them.
FWIW, the wet grip is outstanding!!! It has the same level of wet grip as the Toyo's did in the dry!!! Now that's saying something... :)
RDM
Garry
Postby Garry » Tue Feb 20, 2007 8:52 am
They dont seem to work as well on VW's. rjastra has them as OEM on his PoLo GTI (16\") and Black04RSC has the same on his Golf GTI (17\") and they make heaps of noise as in tyre rumble on coarse road surfaces and squealing through corners. Driving through a set of corners sounds like an American car chase in a B-grade movie. They seem to hang on OK till the dreaded FWD understeer kicks in and they plough across the road. They are wearing out pretty quick on rjastra's PoLo as well. I'm not particularly impressed with them. The ones they have are made in Germany. Maybe the French ones are better? And maybe they work better on an MX5 than they do on a tarted up shopping trolley?
RDM
Postby RDM » Tue Feb 20, 2007 10:20 am
[quote="RDM"]
[/quote]
Oops... I should also add that when they wear down a bit, the wet weather grip becomes atrocious and it aquaplanes quite alot (so be careful). The tread pattern is made of several solid ribs along the length of the rolling surface, so when the tread wears down, there's no evacuation of the water... but then again, I do tend to use my tyres right down past the wear marker - ie until it's not there anymore... :)
Hmmm Gary, it's interesting you should say that about the OEM fitment on VWs (there are plenty of reasons why they wouldn't behave the same on a VW - higher centre of mass, heavier weight, FWD, chocolate bar chassis - not that I don't like them)... When I first got my 16s, they didn't feel all that great (especially having just come off the 17s). But after a few spirited runs and the usual suburban slalom, I've grown used to the increased flex but they still stick like poo to the proverbial blanket... :) For the price, I reckon they're worth trying out just for the sake of science. They are cheaper than the Michelin, Dunlop and Bridgestone alternatives and no doubt better than the Falken, Sumitomo, Kuhmo, Hankook etc options... plus I think you can still get a freebie Conti golf umbrella with a full set of Conti tyres... :mrgreen: As for wear, my Toyos lasted a mere 15k, then my first set of Conti's lasted 30k of similar driving (including trackdays). And my current set are at 15k now and still look on track to make 30k without a problem. :)
RDM
tk421
Postby tk421 » Sun Feb 25, 2007 3:11 pm
Chris P wrote: However these tyres performed better if immediately after I braked I punched it into and through the corner (as if trying to induce oversteer) and they stuck on catapulting me through even quicker. I simply cannot believe it.
I would be interested if you can still do this a week from now.... nuh don't think so :P 8)
98 NB8A, Mania CAI, Eibachs and Bilsteins, Whiteline brace, Starcorp's, DBA Slotted and asstd bling, FM butterfly brace. FFS coldside and the whiiiinnne. Now 138rwkw (Glory Run :) ) More with tuning.
http://users.tpg.com.au/usethe4c/Green+Machine.jpg
