Suspension Choices - What to Pick?
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Feb 12, 2007 1:10 pm
tein ss are great. I just got them about a month ago and cannot fault them. There is a 54sec (around clubman at qr) evo 8 with them so they do work around the track.
Boags
Postby Boags » Mon Feb 12, 2007 1:48 pm
16bit wrote:tein ss are great. I just got them about a month ago and cannot fault them. There is a 54sec (around clubman at qr) evo 8 with them so they do work around the track.
I think it is 54sec around the Sprint, and 59 around the Clubman. Still F'ing quick though! 8)
I'd go the teins over the Bilsteins. This car is going to be a monster. :mrgreen:
Boags
Sheck
Postby Sheck » Mon Feb 12, 2007 2:23 pm
not sure how good they are but you can buy new buddy club coilovers for $2000 from option 1 garage. They have 8/6 kg/mm spring rates i belive.
I'd say they would be on par with the tein flex and bilsiens.
Dave
Duj
Postby Duj » Mon Feb 12, 2007 2:35 pm
jus remember you have 9000Rpm to play with! 8)
Currently driving an 01' GS300 2jz...
Adam_NAclubman
Postby Adam_NAclubman » Tue Feb 13, 2007 8:38 am
lil_mike wrote:king springs are useless unless i want to kill the handling
But you want to put a widebody kit on it with an extra 3 inches each side and presumably have wheels that are out at the edge of those guards?
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Adam_NAclubman
Postby Adam_NAclubman » Tue Feb 13, 2007 1:11 pm
Wheelbase is front to back. Track is side to side.
And no, going that wide will completely throw out the steering geometry
Adam_NAclubman
Postby Adam_NAclubman » Wed Feb 14, 2007 12:49 am
You're going to want to run way more camber and way less castor and you'll probably go through front wheel bearings quite quickly.
Why not just leave it as it is and enjoy it, rather than spending more money on it and ending up with something that won't be eligible for anything. Your mechanic will say that you can do this and that... but he knows it will take a lot of hours worth of work to do it, at a cost to you of what... $60 an hour?
adamjp
Postby adamjp » Wed Feb 14, 2007 8:01 am
If you are serious about race use as the primary then I suggest that you consider coilovers from
Spax http://www.spax.co.uk/
Proflex http://www.proflex-shockabsorbers.com/
Drummond Motor Sports http://www.dmshocks.com/
or Murray Coote (Aus made using Proflex parts - very popular in the rally scene) on 07 5494 8177.
All the above companies are either built with racing as the first use or offer a product that is. IMHO the TIENs are popular because of the JDM effect and their availability from Whiteline, but they would not be my first choice for a track car. But it does depend on what kind of competition work you intend to do.
All of the above can be rebuilt quickly here in Australia, with some companies offering a rapid turnaround time to get you back on the track.
Adam
Benny
Postby Benny » Wed Feb 14, 2007 9:53 am
Just because a damper is stiff, it doesn't mean it will handle well.
After, every road has bumps in it, and if your suspension is very stiff, all the car will do on a bumpy road is bounce up and down, and the tyres can even loose contact with the road.
This does not make for fast track times.
The real trick is wheel control, and this is what you pay your money for.
A car can have quite soft suspension, and still handle and grip really well if the up and down motion of the wheels and tyres are well controlled and not allowed to make any movement which is not desireable.
I have PSS9's on my SP, and I'm very happy with them.
It goes around Wakefield with the best of them, yet the ride is very comfortable. So comfortable that you don't even notice it.
I have experimented with the settings on the track, and I've found that NOT having them set to full hard is the way to go. I usually have the fronts set to one or 2 notches off full hard, ad the rears on the middle setting and I find this gives the car very good balance in the corners allowing me to use the throttle to steer the rear end and the steering wheel to control the front.
Putting the rears to full hard just makes the car oversteer all over the place.
With my normal track settings the car can just ride up over the bumps without ever lifting the wheel off the tarmac.
This means I have full grip everywhere.
And isn't that what you want?
Ted
Postby Ted » Wed Feb 14, 2007 10:10 am
One thing I would definitely look at, is your weight distribution given that it is now running a chook cooker. Buying something off the shelf for a 1100kg car with 52/48 weight distribution may not work for you. On the plus side, coilovers with a small ID generic spring platform means that you can just order new springs and get your shocks re-valved if the valving and adjustability doesn't suit.
For $3K, and if you want a competition setup, I would look at getting some Bilstein bodies with coilover collars and springs. At least this will get you into a 36mm monotube. For about $100-$150 per shock, you can even get external rebound adjustment added.
BTW a well setup car will ride so well that you would think its on the softest springs available even though its running 800lb springs. Just remember that the goal is to keep the tyres on the deck and the body above not bouncing any more than it should. So look at amount of travel you can get (both droop and compression), very important on a MX5. Look at the geometry, esp the lower arms. Getting more track can work well, but look at the stress you will place on the components.
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
