Suspension Options?
GP
Suspension Options?
Postby GP » Fri Feb 09, 2007 11:14 am
My NA Import has always felt very stiff in the suspension department. I've never dríven any others so didn't think much of it until I had a wheel alignment done. The mechanic who did the Job had owned one and has worked on many and he said it has the stiffest suspension he's ever seen.
If I push down on the front or rear guard the metal flexes before I can get about 10mm movement.
My question is whether this is normal?
Did they come with optional suspension?
I've had alook and everything looks stock standard {i.e. All the same colour as the under body}
Graham
Babalouie
godfather of saké
Postby Babalouie » Fri Feb 09, 2007 11:42 pm
Poke your head under the guards and see....what colour are the springs and shocks. Unless they're black, it's probably aftermarket. Also, in Japan Bilsteins were factory optional and they have yellow bodies and black springs, but they aren't as hard as you're describing.
