Installing new shocks (HELP)
Babalouie
godfather of saké
Re: Installing new shocks (HELP)
Postby Babalouie » Sun Feb 04, 2007 9:55 pm
anko7990 wrote:1) based on my limited description, do you think my stocks need replacing?
If they're the original shock then by 115k they'd be long gooorn-ski
anko7990 wrote:2) Do I need to replace the stock springs, given car has only 115km and zero track time?
No you don't have to, but you don't have to go on the track to appreciate the extra grip stiffer springs will provide, and also you might think that lower cars look better too.
anko7990 wrote:3) If I buy off ebay, is it just a matter of organising a wheel and suspension workshop to install for me?
Basically yes, and after installation a wheel alignment is a good idea.
anko7990 wrote:4) are there any additional parts requiring replacement? Manga_blue mentioned replacing bump stocks for $35 per corner. Is this necessary?
If you're sticking with stock springs, then not really. But if you were going for lower springs then cutting off the bumpstops and fitting an aftermarket one is a good idea, but shortening the stock bumpstop works for a lot of ppl too.
anko7990 wrote:5)what should I be paying for installation and alignment?
Roughly 2 hrs labour. Any more than that and the shop really didn't approach the job in an optimal way.
anko7990 wrote:6)is there anything else I should be aware of/watch out for?
Not really!
Adam_NAclubman
Postby Adam_NAclubman » Sun Feb 04, 2007 10:26 pm
If you have access to a vice, install them yourself. For what it would cost in labour you can buy a set of spring compressors and axle stands. Then just take it in for an alignment
mr_rotary
Postby mr_rotary » Mon Feb 05, 2007 2:14 pm
Adam_NAclubman wrote:If you have access to a vice, install them yourself. For what it would cost in labour you can buy a set of spring compressors and axle stands. Then just take it in for an alignment
How hard a job is it to actually replace the shocks? I have never done it as I usually palm off suspension work but do my own work on the car. I have heard people say it's easy - true/false?
Babalouie
godfather of saké
Postby Babalouie » Mon Feb 05, 2007 3:44 pm
mr_rotary wrote:How hard a job is it to actually replace the shocks? I have never done it as I usually palm off suspension work but do my own work on the car. I have heard people say it's easy - true/false?
Judge for yourself:
http://www.sandiegomiataclub.org/sdmc/g ... hocks.html
Boags
Postby Boags » Mon Feb 05, 2007 7:18 pm
I have taken my suspension out twice now, the second time it took me an hour per corner with out any help... It isn't too hard, but the right tools make it much easier.
No problems Anko! 8)
Boags
bigdog
King of the kennel
Postby bigdog » Fri Feb 09, 2007 9:34 pm
Mania quote $150 to $180 - but that's for suspension thay have sold you - would likely be dearer if you supplied the shocks and springs. In a similar vein I have had tyre shops refuse to fit tyres that I supplied - they reckon they couldn't be responsible for the condition of the tyres if they didn't sell them.
bigdog
King of the kennel
Postby bigdog » Fri Feb 09, 2007 10:18 pm
Cheep and light too!! :P :P Direct Wheels Blacktown or Mania sell them.
mr_rotary
Postby mr_rotary » Sun Feb 11, 2007 5:23 pm
Judge for yourself:
Thanks for the link - looks pretty straightforward, now to find the time :lol:
