Spring rate for tarmac rally?
greenMachine
Postby greenMachine » Thu Jan 18, 2007 8:08 pm
Spring rates work with shock absorber rates - no good just picking the 'best' of one, they need to be matched to each other and the car.
See also the discussion of bushes, which also have a major bearing on the handling of the car.
greenMachine
Postby greenMachine » Thu Jan 18, 2007 9:56 pm
I run PSS9s in my NB, which have identical spring rates front and rear, not sure what rates but they are on the stiff side I believe. Others swear by heavier fronts than rears. All I will say is I have no intention of fiddling - Mr Bilstein got this one right enough for me :lol:
I suggest you drive a selection of cars to better understand the tradeoffs of different setups, at least search for past threads on the subject. You could also talk to the engineers at a good suspension shop - one that does serious race cars as well as road cars. Be prepared to buy a package of springs/shocks/bushes. Not necessarily all at once, but know what springs go with what shock absorbers with what bushes. Also, if you are pulling springs/shocks out, how many times do you want to do it (or what is the least number of times you can afford to do it)?
By the way, what use will the car have - fast road, road/track, track only? If its a road car, especially a daily driver, think carefully before going stiff. A test drive won't give you much idea of how you will feel about that setup in six months.
Good luck, its a complex subject, with as many views as there are posters on this board :shock:
Ted
Postby Ted » Fri Jan 19, 2007 12:55 pm
I ran 250F/200R in my car (1990 NA) in Targa Tas 2000 on Koni yellow bodies revalved. Pretty ordinary setup really. I know that Murray had a square setup (300) in the factory cars (NB), but running good short stroke shocks. You can get away with heavy springs if you have a good chassis and excellent shocks to control the body.
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
Ted
Postby Ted » Fri Jan 19, 2007 10:13 pm
Its not so much the spring rate that was tricky, more amount of clearance, wheel travel and shock degradation. Some of the front running cars will see upwards of 600lb springs, but have the shocks to control it. Good fast bump and rebound as opposed to slow bump. Another problem was simply the shocks getting too hot, 30-50km stages will do that to you.
I have seen track MX5s running anywhere from 350 to 650lb fronts. I like 350-375 fronts.
greenMachine
Postby greenMachine » Sat Jan 20, 2007 12:51 am
Klint, I haven't looked at what other cars use, but fwiw I suspect that might be worse than useless, it could lead you in the wrong direction.
Things like weight, and weight distribution, suspension travel and geometry of suspension and shock absorber will be quite different on a WRX (as a frinstance) compared to a MX. Put another way, compare apples with apples.
As I said, this is a complex subject if you plan to master it yourself.
4sfed5
Postby 4sfed5 » Sat Jan 20, 2007 2:12 pm
dont the TEIN coilovers come with 6kg/4kg springs from the factory??????????
CT
Postby CT » Sun Jan 21, 2007 6:50 am
Doesn't matter which spring they come with - you can get springs made to suit. Kings have made springs for me to suit the Flex. I have also found that NB cars take more rear spring than NA cars - most likely due to increased chassis rigidity. For anything but a racetrack smooth surface, you want to make sure you have very good suspension travel and compliant spring and damping rates. 8)
