Is this alignment spec suitable for street driving
Posted: Sun Jan 07, 2007 11:37 am
by Mr Starlet
Hi everyone
Just had the car back from the alignment shop (Fulcrum @ Marooka) and these are the final specs they derived at...
Rear
Camber -2.35 L -2.10 R
Toe +1mm L +0.9mm R
Front
Castor +4.22 L +3.98 R
Camber -1.95 L -1.76 R
Toe +1.1mmL +1.1mmR
Are there specs too agreesive for everyday driving with the odd occasional run up the hills? I've just spent a good amount on tyres (Toyo T1R) so ideally I'll be after a setting with best tyre wear and a safe alignment specs for when I head for the hills.
What does everyone recon?
Minh
Posted: Sun Jan 07, 2007 12:26 pm
by zoomzoom
In my opinion it has far too much rear and not enough front camber. Also the front should really be running more castor. More rear camber than front is really a setup for front wheel drives.
Check out this thread where we went through it. I ended up going -1.5 all round and it felt great. I certainly wouldnt go much more just for road driving. I did take it to the track with these specs and it felt great but could probably go with about -2.0 on the front and leave the rear at -1.5.
My Specs(and I know they were within 0.01 because I did it myself)
Front
camber -1.5* left and right
castor +4.5* left +4.0* right
toe 1mm in each side(2.0mm total)
rear
toe 0.5mm in each side(1.0mm total)
Posted: Sun Jan 07, 2007 1:24 pm
by Mr Starlet
so for best wear out of tyres, would -1.0 all the way around be too subtle?
Posted: Sun Jan 07, 2007 4:07 pm
by zoomzoom
my tyres seem to be wearing quite well, but I do tend to throw the car through corners a bit. I guess it depends what type of driver you are as to how aggressive you set the car up.
