OT - IS200 Wheel alignment specs
Casey
Postby Casey » Sat Jan 06, 2007 4:05 pm
Can anyone point me to where I could find some decent specs for an IS200 wheel alignment? The daily driver needs a tweak :| Just a good street spec, don't want to punish the inside edges too much.
White SP Image
deez
Postby deez » Sat Jan 06, 2007 7:37 pm
Can't exactly help you but I can suggest heading to the forums at
http://jdmstyletuning.com There are quite a number of IS200 drivers on there and I'm pretty sure they can help you out :)
89 Eunos Roadster
StanTheMan
Postby StanTheMan » Sun Jan 07, 2007 8:11 pm
you could also go straight to the source........
and most of them do hang out on JDM.....like deez said
http://forum.altezzaclub.org.au
Casey
Postby Casey » Sun Jan 07, 2007 9:20 pm
Thanks guys. Interestingly the Lexus employs a similar method of adjustment as the MX5 using the eccentric washers. Just mounted outboard rather then inboard.
White SP Image
