konis back in, but not right.
Posted: Sun Dec 31, 2006 12:02 pm
by mossy
I've taken the flex out and reinstalled the konis but the left rear is sitting higher than the right rear, took it for a spin but its still the same??
Re: konis back in, but not right.
Posted: Sun Dec 31, 2006 3:45 pm
by fastfreddygassit
mossy wrote:I've taken the flex out and reinstalled the konis but the left rear is sitting higher than the right rear, took it for a spin but its still the same??
Ican't see why it would have changed but are the spring perch heights the same? (there are 3 settings)
And possibly the springs (or even the dampener) aren't seated correctly?
Posted: Sun Dec 31, 2006 5:29 pm
by Mick93
Time to get the messuring tape out and go over it
Posted: Mon Jan 01, 2007 8:00 pm
by mossy
I might take the wheel off again and check that the spring is seated right then measure, my driveway leans a tiny bit so maybe thats contributing slightly.
Posted: Mon Jan 01, 2007 9:25 pm
by meanmx
I had that happen to mine and I think the sway bar shifted to the side a bit. A wheel alignment fixed it all up.
Ben
Posted: Tue Jan 09, 2007 4:27 pm
by Mr Starlet
check your top hat bolt and make sure that it's tighten down, if it hadn't the spring load would push up on the hat and so will raise that corner.
