konis back in, but not right.
mossy
Postby mossy » Sun Dec 31, 2006 12:02 pm
I've taken the flex out and reinstalled the konis but the left rear is sitting higher than the right rear, took it for a spin but its still the same??
Re: konis back in, but not right.
Postby fastfreddygassit » Sun Dec 31, 2006 3:45 pm
mossy wrote:I've taken the flex out and reinstalled the konis but the left rear is sitting higher than the right rear, took it for a spin but its still the same??
Ican't see why it would have changed but are the spring perch heights the same? (there are 3 settings)
And possibly the springs (or even the dampener) aren't seated correctly?
Mick93
Postby Mick93 » Sun Dec 31, 2006 5:29 pm
Time to get the messuring tape out and go over it
mossy
Postby mossy » Mon Jan 01, 2007 8:00 pm
I might take the wheel off again and check that the spring is seated right then measure, my driveway leans a tiny bit so maybe thats contributing slightly.
meanmx
Postby meanmx » Mon Jan 01, 2007 9:25 pm
I had that happen to mine and I think the sway bar shifted to the side a bit. A wheel alignment fixed it all up.
Ben
2014 VW Mk7 Golf R
Mr Starlet
Postby Mr Starlet » Tue Jan 09, 2007 4:27 pm
check your top hat bolt and make sure that it's tighten down, if it hadn't the spring load would push up on the hat and so will raise that corner.
