Offset +42 or +47 for 17\"x7??
Posted: Mon Dec 18, 2006 10:32 pm
by Roderic
Hey All,
I'm still tossing up the idea of getting a new set of 17\" Rims.
I've got an NA6 with NA8 Brakes and looking at a nice set of rims in 17x7.
They are available in +42 and +47 offets, just wondering which is best suited??
Thanks in advance
Rod.
Posted: Tue Dec 19, 2006 12:41 am
by Adam_NAclubman
+17 would be better..... Definitely +42 over +47, but you're still going to end up with wheels that are over an inch inboard from the edge of the guards
Posted: Tue Dec 19, 2006 10:05 am
by Roderic
Isnt stock +45?
Posted: Tue Dec 19, 2006 10:11 am
by Adam_NAclubman
On a narrow rim, yeah
Posted: Tue Dec 19, 2006 10:55 am
by irwin83r
http://www.1010tires.com/WheelOffsetCalculator.asp
go here and have a play.
but basically 1inch wider (25mm or so) or 12.5mm each side pluse your offset difference.
Posted: Tue Dec 19, 2006 4:21 pm
by deez
+42 is better out of the two. However I've found that for a 7\" wide rim, it looks better with a +40 or lower.
If you don't want to roll your guards, anything from +40 to +30 should look pretty schmick :)
