hi all
just bought rear brace from mania
i know it bolts somewhere on the rear alignment bolts but not sure.
if anyone has a pic of one on their car it will be a great help
do you unscrew the bolt right off ?
if so which one ?
all confused
micksta
rear chassis brace install
90 ltd edition
- StanTheMan
It should bolt on from the rear of the rear subframe.
make sure you mark where the adjustment washers are. at the front & rear of the rear subframe.
try to get someone to help you unbolt the bolts to make sure nothing gets unajusted. Get one person to hold the bolt towards the front to stay steady as you loosen the rear one.
I placed the brace between the bolt & that adjustment washer. & tighten again.
I' did get another wheel allingment done just after installation.
It only fits one way to clear the exshaust
I also had to dremel out one of the bolt holes slightly to make it fit.
hold it up against it & see if you need to modify it before you go unbolting.
hope thats the correct procedure & hope it helps.
pics....to lazy for that right this minute.
- StanTheMan
- StanTheMan
