15\" JDM look...how to?
deez
Postby deez » Thu Nov 02, 2006 10:26 pm
Hi guys,
I've just purchased my first car last week, a red NA6 :D Apart from a few minor things that needs to be fixed up I'm pretty happy with the way things are. The previous owner had put 17\" Lenso S7 Modify's on the car and down where I live (South Sydney) the roads must be a lot worse than where he is....the car keeps crashing on every little bump and ditch in the road to the point that its becoming unbearable :cry:
So, I'm planning to sell them off and get myself a set of 15\" Black Racing Pro N1's in grey for that fat JDM look 8) http://www.arw.co.jp/wheel/blackracing/pro-n1.html
I'm a total beginner and so was wondering if I can get some advice on:
1. Where can I buy them from? Looked at many places, no luck so far....
2. What wheel width, offset, etc should I be looking at?
3. What tyre width? 195 or 205?
4. Are there aftermarket alloys that are just not meant to be put onto a RWD car due to different offsets from FWD? What are ideal offsets for a RWD?
5. What tyre height/thickness should I be looking at?
Thanks in advance for your response!
kula
Postby kula » Thu Nov 02, 2006 10:36 pm
welcome!
nice wheels
buddyclub P1s are similar.. and can be found everywhere
195/50/15 on a 15x7 wheel will look good and fit
about a +45 ofset is standard but wont really look dishy.
+30 to +20 is what you want
youll probly have to lip your guards.
deez
Postby deez » Thu Nov 02, 2006 10:45 pm
kula wrote:welcome!
Thanks for the welcome kula :)
Sorry if this is a dumb question...for 195/50/15, I know that 195 is the width of the tyre...what do 50 and 15 stand for?
How would a +45 offset look on the NA6? By standard, do you mean that +45 is the standard offset from the factory?
Without rolling or lipping the guards, what kind of offset can be achieved? Please bear with my silly questions....thanks :?
Boags
Postby Boags » Thu Nov 02, 2006 10:55 pm
deez wrote:Thanks for the welcome kula :)
Welcome deez! And well done on your purchase! The 50 is the profile of the tyre, it means that the "height" of the tyre - from rim to outer edge - will be 50% of the width (195), and the 15 is your rim in inches...
+45 is factory, and I have no idea what you can run without having to roll the guards sorry...
Boags 8)
deez
Postby deez » Fri Nov 03, 2006 9:45 am
Thanks for your replies guys :)
I think I know what I'm after now...a +30 offset since the rims are smaller than slugoids and the suspension isnt really lowered.
Has anyone tried or have seen someone using 205 tyres on an NA6? Seems that most people on the forum recommend using 195 instead. Is 205 a bad thing for a NA6?
Thanks.
Babalouie
godfather of saké
Postby Babalouie » Fri Nov 03, 2006 11:10 am
Don't be scared of rolling your guards...if you want the wheels to be pushed right out to the edges of the guards, it's necessary. +30 offset on a 6.5in rim won't be very dished at all.
deez
Postby deez » Fri Nov 03, 2006 11:37 am
Babalouie wrote:Don't be scared of rolling your guards...if you want the wheels to be pushed right out to the edges of the guards, it's necessary. +30 offset on a 6.5in rim won't be very dished at all.
Babalouie.....that's the car from jdmtuning forums eh? I read the specs and its running some crazy offsets... something like +15? Does that NA6 have rolled guards?
Babalouie
godfather of saké
Postby Babalouie » Fri Nov 03, 2006 12:04 pm
deez wrote:Babalouie.....that's the car from jdmtuning forums eh? I read the specs and its running some crazy offsets... something like +15? Does that NA6 have rolled guards?
Yes, +15 offset and yes it's got rolled guards. You can actually see in that pic that the rear wheelarch lip is folded up, startng from just above the beltline.
...and it's an NA8 BTW :D
Here's a shot of the front wheelarch
No rubbing at all, not even drifting at track speed when you get onto lots of opposite lock.
Andy Wana
Postby Andy Wana » Fri Nov 03, 2006 12:53 pm
Babalouie, you should post the rest of the photos up here
Saw your interview and gallery shots at JDMST
I am thoroughly impressed with the photos by Felix Alim and the mods carried out to your car
I ♥ asymmetry
EGG80X
Postby EGG80X » Fri Nov 03, 2006 3:12 pm
here are some eudm dish....
25 Offset on 7\" wide rims running 195/55r15
no scrubbing at all.....
will be interesting when I run 9\" wide at offset 30 lol
Hopefully I'll get some photos soon
deez
Postby deez » Fri Nov 03, 2006 3:43 pm
EGG80X wrote:here are some eudm dish....
25 Offset on 7" wide rims running 195/55r15
will be interesting when I run 9" wide at offset 30 lol
Interesting....makes me think again how far out wide I can go with the offset thing without rolling the guards 8) (cost issue really....I'm broke as it is without having to do body mods :cry:
Babalouie
godfather of saké
Postby Babalouie » Fri Nov 03, 2006 4:27 pm
Guard rolling isn't expensive....I paid $25 per guard, but make sure the guy who does it is good tho...I've had jobs on other cars done which were shockingly poor.
Generally speaking, on an NA you have a bit less room under the guards than you have an an NB. With guard rolling the max you can go is +14 with a 6.5in wide rim and +20 with a 7in rim. With 8inches, by rights +32 might be doable, but then you might have some clearance issues on the inside of the wheel :)
deez
Postby deez » Fri Nov 03, 2006 4:43 pm
Thanks for the suggestions :) Can you recommend a good place for guard rolling in Sydney? Thanks.
Babalouie
godfather of saké
Postby Babalouie » Fri Nov 03, 2006 5:38 pm
Actually no...the guy did a great job on my MX5, took his time, got each side looking the same, etc, but when I took my other car to him, he was in a hurry, started bashing the guard with a hammer, etc :(
So yeah, if you find a good place to get it done, let me know, I'm on the lookout too :D
irwin83r
Postby irwin83r » Fri Nov 03, 2006 6:11 pm
thats only because its running the 4x4 suspension. :D
damn dish looks sexy though..
15x7's will be fine i'd go 205... the wider you go the better it looks. 215 would be widest legal and prolly in my opinion best looking.
i did run 225's looked great felt bouncy and squirmy. but couldnt damage my rims even if i tried and looked PHAT as!! :D
it really depends what look your after.. you can go narrow ruber to get the drifto look where the sidewalls tapper in wards slightly.
or like i tend to go the phatt racey look with the widest rubber you can get on to small diameter rims.
if your having trouble getting your melon round all the numbers go to this site
http://www.1010tires.com/tech.asp
and have a wonder. theres all you need to know and alot of handy tools to use when checking sizes.
as far as i know with legality its basical 1inch wider max width, rolling diameter (not rim dia) and 50mm wider track (1 inch a side offset sorta kinda)
correct me if im wrong ppl.
