standard NB wheel sizes
irwin83r
Postby irwin83r » Mon Oct 23, 2006 9:49 pm
do the size of the NB series wheels change in width between 8A 8B 8C SE and SP??
i ask because the boys in blue enforce one inch over standard width.. but if the running gear is the same from 8A to latest 8C but they have different wheel sizes...
Craig
Postby Craig » Tue Oct 24, 2006 1:13 am
NB8A had 15x6 with a 16x? as an optional upgrade.
NB8B/C/SP were 16x6.5
SE is 17x7
irwin83r
Postby irwin83r » Tue Oct 24, 2006 1:25 am
so if the SE is 7\" wide on the same axles/hub/stub shaft what ever and one inch over factory is legal.. one could get away with 8\" wide rims.. or atleast engineer them easy
:D
Craig
Postby Craig » Tue Oct 24, 2006 1:30 am
Bet the RTA doesn't see it that way but! Find out what the optional NB8A 16's were and go from there, 100% legal then! :)
Garry
Postby Garry » Tue Oct 24, 2006 9:44 am
The \"standard\" rim for you car is the one that's described on the tyre placard. So legaly you have to use that as the starting point. You could of course accidentally replace the NB8A tyre placard with one from an SE which would allow you to run 18*8's. But I never said that. *cough*
CT
Postby CT » Tue Oct 24, 2006 4:42 pm
The most important things is wheel track. Regardless of your wheels, you must not increase your wheel track by more than 1 inch. In these days of plus 1,2 and 3 fitments, I doubt plod is going to worry about an MX5 with a 1 inch diameter larger rim - unless of course it's chrome and the bling police lock you up. 8)
irwin83r
Postby irwin83r » Tue Oct 24, 2006 7:22 pm
CT wrote:The most important things is wheel track. Regardless of your wheels, you must not increase your wheel track by more than 1 inch. In these days of plus 1,2 and 3 fitments, I doubt plod is going to worry about an MX5 with a 1 inch diameter larger rim - unless of course it's chrome and the bling police lock you up. 8)
diameter?? pfft
im talking about width :D
i'm not sure what tyres would be available 8" wide that stayed within the 3% running diameter of the originals.. for speedo reasons...
StanTheMan
Postby StanTheMan » Tue Oct 24, 2006 9:54 pm
wheel track is the witdth of the track & is measured from centre of tyre to of one side to the centre of tyre of the other side. It gets affected by offset.
standard offset is 45mm
a 35mm offset rimm would make the track 20mm wider.
hence most of those dishy dorifto spec JDM market rimms which have15mm offet or even less, are illega,l as they widen the track a bit more than mr plod wants to allow us to. Of course if you can prove & get an engineer to sign a piece of paper to say they are safer & carry that piec of paper in you glove box mr plod can't do a thing.
thats the basics......hope that helps :mrgreen:
Charlie Brown
Postby Charlie Brown » Thu Oct 26, 2006 11:07 pm
Trouble with widening the track is that you can introduce bump steer.
You might not pick it up on the road but you will on the track.
Anyone thought that possibly the best handling car around – the Lotus Elise - runs relatively skinny wheels? Must be a lesson there somewhere? Weight maybe?
Boags
Postby Boags » Fri Oct 27, 2006 10:04 am
The NC can hold more Gs than the Lotus Elise - Wheels Magazine.
