I'm in the process of installing a second hand EDFC unit and am looking at 4 of the grub screws that come with it. The manual says that these are supposed to be gold, but mine are black, and exactly the same as the ones in the top of the shocks that need to be replaced.
Can someone who has done this install tell me whether there is a difference between the black and gold grub screws?
Brad
Tein EDFC Question
- Brad
Tein EDFC Question
- godfather of saké
- Brad
I'm thinking they may be a different length, though the diagram has drawn then the same size. I might give Fulcrum a call and see, worst case scenario is to buy new ones which are supposably $5US....owch
Otherwise it's all installed, though errors are showing as the motors are not connected.
- Brett_MX5
Re: Tein EDFC Question
Brad wrote:Can someone who has done this install tell me whether there is a difference between the black and gold grub screws?
The gold ones are slightly longer than the black ones - I have no idea why this is tho.
You could try Fulcrum Suspension for an Aus supplier instead of getting them overseas
http://www.superpro.com.au/where_to_buy ... n_qld.html
"You tried your best and failed miserably,
The lesson is, never try"
-Homer Simpson
-Homer Simpson
- CT
- Brad
CT wrote:As long as they are flush when you fit them it shouldn't be a drama. Mine were silver and the EDFC ones are black. It's the right model motors yeah?
No, that's was the other problem which I've fixed, the motors were 2xM12 and 2xM14. The MX5 needs M12 so I've had sleeves made up for the inside of the M14 to fit over the shock.
I'll get them installed with the back ones and see how it goes.
