Rim and tyre weight?
Matty
Postby Matty » Sun Oct 08, 2006 8:23 pm
16kg is not too bad, but ~13-14 is better.
irwin83r
Postby irwin83r » Mon Oct 09, 2006 8:20 pm
what size rim, what size/make tyre??
i hear tyre wieght varies a fair amount depending on construction.. semi slicks for example have really thick/stiff side walls which makes them a bit heavier??
trader
rim and tyre weight
Postby trader » Wed Nov 15, 2006 12:29 pm
I run momos 15x7 which weigh 17.2 Kgs. Stick like glue (except in the wet). Every time I change from my stock 14's (11 KG's) I feel the weight difference and wonder what damage I'm doing to the suspension bushes. The ride is noticably different - far more nimble with the lightweights and more chuckable. I wouldnt like to go any heavier than mine..they tend to crash over bumps more but that could be because of sidewall height.
NB SE, NA 1.8.
deez
Postby deez » Fri Nov 17, 2006 1:58 pm
Slightly off topic:
Just a general question, is 5.6kg for a 15x7\" rim considered a good weight? Or is that considered heavy?
Keeping in mind that its a replica rim.
Boags
Postby Boags » Fri Nov 17, 2006 2:01 pm
My \"lightweight\" 15x6.5s are just under 5. So that is very good, especially for a replica.
RDM
Re: rim and tyre weight
Postby RDM » Sat Nov 18, 2006 9:57 am
[quote="trader"]I run momos 15x7 which weigh 17.2 Kgs.[/quote]
The OEM 17" SE Racing Hart rims with 205/40 R888 semi slicks weighs just on 17kg per corner... :(
And the difference between these and the OEM 16" rims is VERY noticable. As Trader said, it tends to feel sluggish with the 17" but they do steer and grip better.
Using 16s for the road and 17s for the track... :)
RDM
