Without knowing first hand the difference, I'd be inclined to say that the PSS9's would be a firmer ride than the SS and more track orientated, of course that woudl also depend a lot on what spring rate you spec'ed and valving.
Edit: After a bit of googling I found a few threads. Ground Control are the track version, PSS9 (for the M3 anyway) are apparently softer than the SS.
http://forum.e46fanatics.com/showthread.php?t=345829
Also this thread:
http://www.aus-cartalk.com/viewtopic.ph ... 3d60d24f77
What's better Bilstein PSS9 or TEIN SS????
- Brad
- CT
If you go by price, Bilsteins are more expensive than Tein SS so you must be getting a better product. Not bagging billies but marketing is a powerful thing. They are different price points in the market and probably should not be compared directly. Maybe it's PSS9s vs Tein Flex. BTW, I have the SS's and they are a very competent setup...but I also ahve some flexes as well.
- godfather of saké
CT wrote:If you go by price, Bilsteins are more expensive than Tein SS so you must be getting a better product. Not bagging billies but marketing is a powerful thing. They are different price points in the market and probably should not be compared directly. Maybe it's PSS9s vs Tein Flex. BTW, I have the SS's and they are a very competent setup...but I also ahve some flexes as well.
Well, in Japan, Koni Yellow/Eibach combo is more expensive than Teins
- Benny
I've got the PSS9's in my SP, and I find that they have a very good ride.
Certainly softer than Konis and Kings, but they also have fantastic wheel control.
They never hop or skip, but they never float either.
Just a great combination for comfort and handling.
Just being hard doesn't mean a shock is good.
In fact, quite the reverse. A hard shock will let the car hop and skip over bumps and this means your tyres aren't in contact with the road, and that means you aren't cornering as fast as you could if the tyres were on the road.
- Brad
I agree. On bumpy roads, the Clubman Bilsteins were much harder than the Tein SS's even at full hard, though because of the lower spring rate there was much more roll. The Tein's harder springs allow flatter cornering with better bump absoption due to the valving, it's a matter of tuning the rate to the 'bumpiness' of the road.
