Offset ... need help. Will this wheel fit an NA
JSE
Postby JSE » Tue Sep 12, 2006 7:32 pm
I would like to know what the maximum/minimum offset of a wheel that will fit onto a stock NA6...
I am looking for new wheels but I am not sure if they will fit due to the offset and all that jazz since they have a fair bit of dish on them...
Thanks in advance
Sheck
Postby Sheck » Tue Sep 12, 2006 9:10 pm
alot of the US (drift) guys run a 15x8 in a 0 offset, but comfotably without rubbing i think you can go a 7\" wide in a +20-15. Might need some fender rolling if your suspension is on the soft side or if your really low.
Post some pics and let us see how they look!!! :mrgreen:
Dave
JSE
Postby JSE » Tue Sep 12, 2006 9:53 pm
http://www.bsawheels.com.au/users/ProductDetail.aspx?id=353
these are the ones I'm looking at in 4 or 8hole...
would they fit on a NA6 with king springs and KYB AGX adjustables???
kitkat
Postby kitkat » Tue Sep 12, 2006 10:31 pm
i can fit 15 x 7 15mm offset, wrapped in 195/60 yoko's on our NA6, its dumped on LOW espelir springs... i had no problems :mrgreen:
Adam_NAclubman
Postby Adam_NAclubman » Wed Sep 13, 2006 2:27 am
I've got 15x7 +17's, needed the guards rolled with 195's
Garry
Postby Garry » Wed Sep 13, 2006 9:31 am
35mm offset should fit easily, the stock offset on an NA is 45mm however those wheels are to big and to wide to be legal for an NA.
JSE
Postby JSE » Wed Sep 13, 2006 2:42 pm
I don;t mind about legality issues...I just need to know if they fit or not :) I also have some 10mm wheel spacers if needed...
OMY005
Postby OMY005 » Wed Sep 13, 2006 3:28 pm
The wheels don't have a large 'dish' as the offset says 35/45 it is the spokes that have a large curve in them thus allowing a large 'lip' with the appearance of a large 'dish'. Hope this helps.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Adam_NAclubman
Postby Adam_NAclubman » Wed Sep 13, 2006 3:56 pm
ie they wont sit near the guard and will look a tad silly
Mr Starlet
Postby Mr Starlet » Tue Nov 21, 2006 12:46 am
kitkat wrote:i can fit 15 x 7 15mm offset, wrapped in 195/60 yoko's on our NA6, its dumped on LOW espelir springs... i had no problems :mrgreen:
hmmm...just measured the old school looking rims sitting in the shed, 15x7 +9 offset on 195/50, I too wonder if these would fit on a stock NA with stock camber. My feeling is no but would be good if someone could clarify. Cheers Minh
StanTheMan
Postby StanTheMan » Tue Nov 21, 2006 7:21 am
I think they'll look quite good. However looks are very subjective.......especiallywith the subject of wheels.
Our pommy friend from MX5Nutz.com had some very dischy wheels. 35mm offset. Best dischy wheels i've seen personally.
also check the weight. how heavy are those things.
spacers......gawd getting better every minute......may i suggest you get your No plate off your sig.
:lol: :mrgreen:
RaYmO
Postby RaYmO » Tue Nov 21, 2006 9:48 am
StanTheMan wrote:I think they'll look quite good. However looks are very subjective.......especiallywith the subject of wheels.
:lol: :mrgreen:
Got pics of the dishy rims? :D
StanTheMan
Postby StanTheMan » Tue Nov 21, 2006 10:02 am
35mm offset.......cant recall the width.....but its pretty wide
RaYmO
Postby RaYmO » Tue Nov 21, 2006 10:09 am
Yeah, I saw these on Miata.net early this year on another ride out there.
Its by Rota, I thought they looked absolutely awesome!
If I wasnt going JDM on my ride I would have bought these puppies by now.
StanTheMan
Postby StanTheMan » Tue Nov 21, 2006 10:14 am
16x8 :shock:
