If you have aftermarket wheels...
atomic
Postby atomic » Sun Aug 27, 2006 9:12 pm
... how nicely do your rims sit on the centre hub?
I have a set of 15's that are slightly too big for the hub and I don't want to drive around on just the 4 bolts.
Has anyone else experienced this and what kinda solution did you come up with? Hub rings?
Thanks
Babalouie
godfather of saké
Re: If you have aftermarket wheels...
Postby Babalouie » Sun Aug 27, 2006 9:42 pm
atomic wrote:... how nicely do your rims sit on the centre hub?
Thanks
Yup....hub rings. Cost about $20 for a set of 4.
atomic
Postby atomic » Sun Aug 27, 2006 9:59 pm
thanks.
Is there any place you recommend? Or any wheel/tyre shop should be okay?
Babalouie
godfather of saké
Postby Babalouie » Sun Aug 27, 2006 10:22 pm
atomic wrote:thanks.
I think any tyre shop should be able to sell them to you. I noticed that mine were made by Mullins Wheels (ROH, etc) so they should be readily available.
green_comet
Car Detailing Guru
Postby green_comet » Sun Aug 27, 2006 10:29 pm
Unless you have weird sized wheels, then you will have to get a set machined up. My watanabes were a bitch i couldnt get any rings to suit the wheels.. Plenty to suit the car but not the wheels.
Babalouie
godfather of saké
Postby Babalouie » Sun Aug 27, 2006 10:39 pm
Really? Mu hub rings fit perfectly on my Watanabes...I vaguely recall (not 100% sure) that the outside dia of the Wats are 60mm (same as Enkei) and the inner is 53mm.
Matty
Postby Matty » Sun Aug 27, 2006 10:45 pm
Thanks
hub centering is only to get the wheel temporarily aligned until you do the nuts up. It's the taper on the nuts that does the real locating and load bearing.
So as long as you do the nuts up progressively and evenly you shouldn't have a problem without rings.
atomic
Postby atomic » Sun Aug 27, 2006 11:45 pm
Really? I was under the impression that it wasn't good to be riding on the nuts.
I always thought the bulk of the load was taken by the hub and the nuts were mainly to keep the wheel firmly in place on the hub...
Maybe I'm wrong then...
green_comet
Car Detailing Guru
Postby green_comet » Mon Aug 28, 2006 12:11 am
well i didnt end up finding a set of rings to fit my watanabe's. But i ended up getting my hands on the original watanabe wheel nuts which made the wheels set much more centre. My watanabe wheels have 2 tapers for the nuts to sit in, so the normal nuts i was using werent centering the wheels correctly. But the watanabe nuts solved that problem as they were shaped differently..
Moggy
Postby Moggy » Mon Aug 28, 2006 6:14 am
Depends on the type of wheel and hub. If it's hubcentric it's supposed to have the weight supported on the hub while if it's lugcentric (and most are) it's supposed to have the weight supported on the lugs.
So in other words - it's fine how it is, don't worry about it... :)
Adam_NAclubman
Postby Adam_NAclubman » Mon Aug 28, 2006 12:09 pm
Mullins = CSA
Babalouie
godfather of saké
Postby Babalouie » Mon Aug 28, 2006 2:00 pm
Adam_NAclubman wrote:
Babalouie wrote:I noticed that mine were made by Mullins Wheels (ROH, etc) so they should be readily available.
Mullins = CSA
Yeah well what would I know, I mainly buy japanese wheels :D
Adam_NAclubman
Postby Adam_NAclubman » Tue Aug 29, 2006 2:43 am
Hehehe, I have Buddy club's, Black Racing and Watanabes atm, recently got rid of Longchamp XR4's and Enkei Racing S
My uncle is the CEO of Mullins but I still wouldn't put CSA's on my cars, awful looking wheels
irwin83r
Postby irwin83r » Fri Sep 01, 2006 6:34 pm
ive been running on just the studds and tappered bolts for ages now. no dramas as yet.
but im going to make some all the same... one day :roll:
