NA6 fitted with SE spring/shocks/wheels...and NB8A wheels
- Boyracer
- MX-5 Encyclopedia
Mick from Hume Smash repairs MX5....Imaculate and it looks hot!
- StanTheMan
- Boyracer
- MX-5 Encyclopedia
I have only dríven it around the block but it feels good.
Spranga,Mick told me your car was going in...it probably won't keep the SE wheels,I just put them on to see how it looks...will have NB8A 15s.
All the bits were off my silver SE,had only done 8500km...I was expecting it to sit higher too...the
Tip for anyone else fitting NB shock...in the front..the top of the shock is quite a bit longer than the NA ones,makes them pretty hard to get in,I found the best way to get them in is to loosen the lower control arm so it's out of the way,then they just slip straight in,just have to make sure to mark the camber adjuster bolts.
- Boyracer
- MX-5 Encyclopedia
