Why can't i Run the recomended Pressures in my tyre?
Russellb
RIP Nov 2014
Postby Russellb » Fri Aug 25, 2006 8:08 pm
Why can't I get this wheel to hold recomended Pressure :?:
Image[/img]
My ClubmanRebuild
MX5 SE Rally car is HERE :)
AJ
Postby AJ » Fri Aug 25, 2006 8:20 pm
buggered if i know...........have you checked the valve???? :shock:
XMX5 Rogues
mossy
Postby mossy » Fri Aug 25, 2006 8:22 pm
See if your handbrake is on then check it again. :mrgreen:
StanTheMan
Postby StanTheMan » Fri Aug 25, 2006 8:55 pm
sooo..... what happened. :shock:
Russellb
RIP Nov 2014
Postby Russellb » Fri Aug 25, 2006 8:55 pm
Know I could count on you guys to Help me out :)
I checked the hand brake it is off and the valve is fine
Any other Ideas :?:
My ClubmanRebuild
AJ
Postby AJ » Fri Aug 25, 2006 9:03 pm
i know.........you aren't running bigdogs air in it!!!! :lol:
XMX5 Rogues
bigdog
King of the kennel
Postby bigdog » Fri Aug 25, 2006 10:52 pm
AJ wrote:i know.........you aren't running bigdogs air in it!!!! :lol:
Ahem! Bigdog's Air is no longer available in this country, having been purchased by an off-shore consortium of investors to supply the burgeoning economy in mainland China. I beleive this was covered in recent articles in the Fin Review and New Idea.
It looks to me like this wheel was filled with inferior recycled air containing ten percent ethanol - Mazda have clearly stated that NB's can't handle the 10% ethanol mix.... the results are obvious.
Alf
Postby Alf » Fri Aug 25, 2006 11:47 pm
If you're going into corners hard enough to lose the air like that, you need nitrogen in the tyres and a little snake oil around the beading. That should fix you right up.
Alf.
2015 ND MT GT Crystal White Pearl Mica (pic to come)
