How do I move the piston back during pad change????
Spranga
Postby Spranga » Sat Aug 05, 2006 5:17 pm
I tried to do a pad change today but could not get the brake piston back far enough to put the new pads in. I tried pushing it in with a G clamp but this did not work. Am I missing anything? In the past (with other cars) I have just been able to slowly push the piston back into position. Any ideas would be appreciated. I thought about bleeding the system but would prefer to avoid this.
Dan
kula
Postby kula » Sat Aug 05, 2006 5:30 pm
take the cap of the master cylinder..
i presume u are doing fronts right?
they can be pushed back, while the rears cant, screw them:P
Spranga
Postby Spranga » Sat Aug 05, 2006 6:02 pm
doing the rears :(
Andrew
Postby Andrew » Sat Aug 05, 2006 6:07 pm
you need and alen key :P
adamjp
Postby adamjp » Sat Aug 05, 2006 6:48 pm
Go and buy a big syringe from a chemist (like 1\" thick ~ 100ml). Suck some of the brake fluid out of the resovoir first or run the risk of having it come out under pressure when you put the piston back in.
It is cleaner to suck it out first. I learnt this the hard way a few years back.
Adam
Spranga
Postby Spranga » Sat Aug 05, 2006 7:14 pm
Andrew wrote:you need and alen key :P
Spranga
Postby Spranga » Sat Aug 05, 2006 7:15 pm
adamjp wrote:Go and buy a big syringe from a chemist (like 1" thick ~ 100ml). Suck some of the brake fluid out of the resovoir first or run the risk of having it come out under pressure when you put the piston back in.
Great idea Adam. Thanks for saving me paint work!
Babalouie
godfather of saké
Postby Babalouie » Sat Aug 05, 2006 7:17 pm
If you look at the back of the caliper, there is a little bolt (I think it's 12mm) that looks like it's directly behind the piston. Unscrew it, and it exposes an allen headed thingy. Get your allen key in there and as you turn it, you'll notice that the piston slides back.
Spranga
Postby Spranga » Sat Aug 05, 2006 7:39 pm
Aaah the mystery is revealled! Thanks Babs. I sure could have used that advice at about 2:00pm this afternoon. I had wondered what that bolt was for but did not touch it as I thought it might be under pressure and I did not want to bleed the brakes.
Thanks for your help guys.
Dan
Postby manga_blue » Sat Aug 05, 2006 8:10 pm
There's a little bit more to it after that. Good idea to check http://www.miata.net/garage/brakepad.html
Adam_NAclubman
Postby Adam_NAclubman » Sun Aug 06, 2006 2:22 am
Also helps to push the piston with a finger or two while you turn the allen key
Users browsing this forum: No registered users and 123 guests
