Urgent Advice needed RE: Tyres
Bevan
Postby Bevan » Wed Jul 26, 2006 1:17 pm
Would these be safe to drive on?
Short story. Bought some 17\" wheels and tyres off ebay where the seller said tyres were near new and excellent tread. Two of them (the front two) have obviously been scrubbing on his car as about 2cm of the inside of the tyre is worn down below the tread. I'm going to email him to try and get a partial refund to help purchase two new tyres. That pisses me off cause the main reason I bought it was for thr four \"near new tyres\". :x
If I was still to use them, I'd probably put them on the back. :roll:
Here are some photos:
How it's meant to be
Two tyres that are worn
Postby Okibi » Wed Jul 26, 2006 1:55 pm
sorry Bevan, my ISP is b0rked again; the Optus link to the US has dropped out so I can't see the photos :(
Bevan
Postby Bevan » Wed Jul 26, 2006 2:01 pm
Sent via email. :)
maxwolfie
Postby maxwolfie » Wed Jul 26, 2006 2:05 pm
What a shitter mate...
But to answer your question.. I have NFI
Get his address and we'll pay him a visit lol
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
Postby Okibi » Wed Jul 26, 2006 2:11 pm
It's really hard to tell from the top of the tyre, is the inside \"corner\" of the tyre worn down?
Caused by running too many psi, which is common with 17's because you have to run such a tiny profile to keep your speedo accurate.
People worry they'll bottom out and bend their rim so they over compensate with psi.
I know I did with my 17\" 5zigens.
Bevan
Postby Bevan » Wed Jul 26, 2006 2:24 pm
Another email sent. :)
For those who can see the pics, the gouge is most obvious on the third pic on the right hand side near the white bottle. On the upper side of the tyre you can see how much is gouged out which indicates to me more to do with scrubbing than uneven natural wear.
And yes, it is on the inside of the tyre. :cry:
Postby Okibi » Wed Jul 26, 2006 2:27 pm
Thats the inside edge isn't it?
Bevan
Postby Bevan » Wed Jul 26, 2006 2:29 pm
Okibi wrote:Thats the inside edge isn't it?
Sorry, edited post. Yes, it's the inside edge.
bigdog
King of the kennel
Postby bigdog » Wed Jul 26, 2006 2:30 pm
No wire pokin out the sides - of course they're OK! Seriously Bevan - no problems driving on these - put the good pair on the front and wait till the tread dissapears before buying newies.
Adam_NAclubman
Postby Adam_NAclubman » Wed Jul 26, 2006 3:18 pm
bigdog is almost right.... Put the two good ones on the front and these on the back, then make the tread disapeer then get new ones. And take pics
bigdog
King of the kennel
Postby bigdog » Wed Jul 26, 2006 3:51 pm
Ah now I see wot yer talkin bout Willis! :roll: The tyres have been rubbing on an inner guard bolt or something and worn a groove on the shoulder. Still no problem - if it had really worn away you'd see the steel wire in the bottom of the groove, so the tyre structure is fine from the pictures and safe to drive on the back. If you drop the clutch about a hundred times you can even the tread out so you won't notice it so much.... :P :mrgreen: :roll:
Postby Okibi » Wed Jul 26, 2006 3:55 pm
I don't think they've been rubbing on a bolt or guard, just looks like they were over inflated. I'll take a photo of mine soon.
Bevan
Postby Bevan » Wed Jul 26, 2006 4:07 pm
Okibi wrote:I don't think they've been rubbing on a bolt or guard, just looks like they were over inflated. I'll take a photo of mine soon.
That'd be great thanks! :) I thought overinflation wore the middle of the tyre out though? Or does it get that hot that the inside peels away with the camber?
bigdog wrote:Ah now I see wot yer talkin bout Willis! :roll: The tyres have been rubbing on an inner guard bolt or something and worn a groove on the shoulder. Still no problem - if it had really worn away you'd see the steel wire in the bottom of the groove, so the tyre structure is fine from the pictures and safe to drive on the back. If you drop the clutch about a hundred times you can even the tread out so you won't notice it so much.... :P :mrgreen: :roll:
I've done a close-up on a higher res image and couldn't see any wire. I'm just worried about this bit still coming in contact on the road and wearing down to wire within a few weeks. :| Going to contact the seller and ask to go halves ($160 each) in two new ones regardless of whether I replace them or not. 8)
bigdog
King of the kennel
Postby bigdog » Wed Jul 26, 2006 4:07 pm
maxwolfie wrote:Get his address and we'll pay him a visit lol
Want the Dog and Brother Dave to come to?? :P :mrgreen:
Anyone got a baseball bat??
Edit: we can do a Dinsdale Brothers routine for you if you'd like - nail his head to the coffee table, that sort of thing :mrgreen:
Bevan
Postby Bevan » Wed Jul 26, 2006 4:08 pm
I've got his mobile phone number! :mrgreen:
