Pillow ball upper mount
mattah wrote:Better suspension response.. also adjustable for camber (and some also caster).
Cant see much advantage for a 5 as the shock/spring only goes up & down (double A arm) not rotating like a strut. All the camber and caster adjustment is done with the eccentric mounting of the bushes.
As for response; maybe a very slight difference as the standard top mount has some rubber in it.
Please correct me if I'm wrong.
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
- Matty
