Did yours come with the green Tein top mounts? Are are you using the oem ones?
In my case (I have the Tein top mounts), the lower spring adjuster collar is 25mm away from the bottom of the threaded sleeve on the shock (not the bottom of the threads, but the bottom of the sleeve).
This will get you a ride height of about 320mm from the centre of the wheel to the wheelarch lip...or about 10(ish)cm of ground clearance. As you adjust the spring height, keep in mind that for every 10mm ride height change at the wheel, you need 14mm change of height at the spring...
Also any coilover shop c-spanner will work to adjust the Teins, just go see your friendly race suspension shop.
help! help! with my tein set-up
- godfather of saké
- godfather of saké
- Matty
http://www.tein.com/ti/inst/km64u.pdf
They recommend 23mm up from the lip just below the thread to the bottom of the lower spring seat lock (front and rear) on the NA6/8
