Postby Woo » Tue Jul 11, 2006 7:48 pm
Totally agree that the original Pilots were good. As I wore out the rears I decided to replace them (onto the fronts of course) with a new set of Precedas. These were not preceda II's.
Well I recently needed some more replacements for the original Pilots (now on the rear) and I decided on Preceda II's. The new tyres again went onto the front so the 4000k Precedas went onto the back.
All I can say is why did they change? Hopefully the Preceda II's will be better than the plain precedas. They are a much harder compound and slippery in the wet. I'm just not convinced that Mitchy got it right changing the compound from the original Pilots. However, on a stock car I believe that both the Precedas I & II will serve you well.
Until the Preceda II's go onto the back I wont be able to access the drive, but under brakes and steering they are fantastic as Col says.
btw, the Blue car is kicking twice stock kW through these, so traction will be an issue using just about anything black and round anyway.
Wòó
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
