Does anyone know if you can fit NB8B brake calipers and discs to an NB8A?
Or do they also have a different \"hub\" to hold the caliper further out to suit the larger disc?
NB8B Brakes on an NB8A
- Mr_Q
- Boyracer
- MX-5 Encyclopedia
- Mr_Q
Calipers, discs, hoses (I didn't realise they were a different fitting, I just grabbed them 'cos they were newer than mine
) and front backing plate/dust shield things (the rears were too hard to get off so we just cut the existing ones).
It's a straight forward swap, no problems at all. Now I get to do it all again when I put them onto my NA8.
Mister Q
- CT
- irwin83r
listen to MR CT!
they fit ive done it. and yes you do need a proportioning valve to sort out the rear bias.
also you may need to mod your dust shields.. as the slightly bigger dia rotors will not fit. or you could take them off though i hear this is defective.
not sure if the nb8b dust shield swap over or not... would be worth a try.
see...
http://www.bigllama.com/miata/brake/bigbrake.htm
maybe helpfull
see...
maybe helpfull
- Woo
- Vehicle: 10AE - Turbo
Yes, it works a treat.
Question though, if you do front AND rears, why do you need to fit a proportioning valve.
The ABS on the blue car comes on front and rear at very close to the same point in braking. If anything it's better balanced than before the upgrade.
Are the brake lines the same on a NA as the NB8A ? The lines may need changing if your putting NB8C calipers on as the alignment prong is in a different spot to the NB8A.
Thinking I might put braided lines on rather than new NB8C lines (if I can find some)
Very worthwhile mod
Woo
Very worthwhile mod
Woo
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
- Mr_Q
- CT
Woo wrote:Yes, it works a treat.
Very worthwhile mod
Woo
Because, the NB8A(NA8C also) 255mm front/250mm rear is different to the NB8B 270mm front/276mm rear rotor sizes. The NB8B proportioning is controlled by the ABS/EDB module. The NB8A is controlled by the prop valve fitted adjacent to the master cylinder. Unless the 10AE has electronic proportioning via the ABS module like the NB8B+ models, your front to rear bias will be out and need adjusting. Depending on the model, there are also different master cylinder sizes which also has an impact.
When I drove Andrews car, the first thing I noticed was the rears locking before the fronts. It is easy to tell at speed on the track, maybe not so on the road. Jap models are a whole other story - they have variations we didn't see. If you have the manual OEM prop valve, it may be OK, but its more luck than good management. The later model cars got more rear bias - Matty has looked into this in more detail. Don't forget that running different compound pads front ot rear will also affect bias as will larger rear rubber.
